Old 06-17-2018, 03:33 PM   #1
2018 28' Tommy Bahama
Decatur , Georgia
Airstream interstate AC problem 2018
Howdy,
I have a weeknold 2018 Airstream Interstate. Used AC off campground 30a last weekend and several times off generator. Last night used for four hours on generator. Arrived at canpsite plugged in, nothing, nada, zilch. Tried with generstor same dispiriting result. It’s hot here in Columbus Ohio. I’ve flippef breakers, cut the house batter off and on, tried to take a break and restart everything. Nothing works, not even the fan by itself. If you toggle fan speed between low and high, you can hear a click but nothing else.
If anyone has any ideas on how to get it going again, I will be grateful , extremely grateful.
Best,
Michael
Roasting newbie,
Zeitgeist1 is offline   Reply With Quote
Old 06-17-2018, 03:44 PM   #2
Hi, Michael. Welcome to Air Forums. Your question might be better moved or posted on the Sprinter and B Van portion of this forum, which is where the Interstate people hang out preferentially (here). Even though this is the "repair" etc. portion of Air Forums, the Interstate people tend to concentrate due to the recurrence of certain issues with the van builds.
Our Interstate is older than yours and with different equipment, so I can't comment specifically, but the other folks will be able to give you ideas on what to look for.
Old 06-17-2018, 03:53 PM   #3
rowiebowie's Avatar
2012 Avenue Coach
Corpus Christi , Texas
I don't have the same model, but is your battery disconnect switch in the "connected" position? This is required for my a/c to work. Otherwise, I get the same "click", then nothing, that you describe.
rowiebowie is offline   Reply With Quote
Old 06-17-2018, 04:15 PM   #4
Franklin County , Missouri
Probably not it since you tried your generator but if your power management system is set for 15 amps it may keep the AC off. With generator it should set itself to 20 amps and the AC should run.
AI927 is offline   Reply With Quote
Please help: 2018 Globetrotter => 2018 F-150 Lariat SuperCrew Confirmation ddrg Tow Vehicles 169 07-10-2023 05:38 PM
2018 Jeep Eco-Diesel VS 2018 Expedition? Barretta2 Tow Vehicles 57 03-10-2018 03:39 PM
2017 vs 2018 Airstream Interstate (Can You Help Me) sthrngary Sprinter and B-van Forum 23 09-26-2017 11:11 AM
