Air Conditioner Mounting Bolts
Hello all. Does anybody know the proper torque or gasket compression when installing a Dometic Brisk Air with the drain cups.
The instructions included with the unit call for 40-50 inch pounds, but that is for a single gasket.
When using the drain cups you use two gaskets and all the install instructions say is that the 3/4 inch compressed thickness of the gasket does not apply.
It doesn't tell me what does apply.
Any help would be greatly appreciated.
Thanks, George
