2022 25' Globetrotter
Baton Rouge
, Louisiana
Air Condition Water Leak
I have a new 2022 Globetrotter and one of the Air Conditioner is leaking water on the roof and running down the side of the trailer. Possible causes and repair?
Would appreciate any info.
It sounds like something is blocking the drain pan at the base of the AC unit, now allowing water to drain down through the plastic tubing and out the wheel well.
2022 23' Flying Cloud
2018 22' Sport
Orange
My 2022 FC did the same thing when brand new. I had to remove the A/C return grills and take the kink out of one of the drain pan hoses. The hoses are clear plastic lines that are teed together and run down the side to the wheel well.
We have a 2022 Globetrotter 25 FB with one ac and just noticed the same issue, water on the roof and nothing coming out the drain. were you able to locate and solve the issue? I assume one can access the drain pan by removing the exterior cover?
2018 22' Sport
Orange
Remove the air return grills inside the trailer and look for the clear plastic hoses that drain the pans and look for kinks that will block the water flow.
Baton Rouge
, Louisiana
Yes I think that it is fixed now. I removed the return air grills for the rear air conditioner and noticed that the clear hose was stuck to the underside of the air box. It had some sort of adhesive holding it up so it was causing the drain pan to overfill and run onto the roof. I pulled the hose down allowing the pan to drain properly. I hope that this explanation helps.
