Did you remove and clean the burner assembly, and remove and clean the orifice below it by soaking in alcohol? (do not poke anything into the orifice!). If I recall the orifice unscrews with a 7mm socket on the Dometic cooktops. Also, an occasional blip here and there of yellow is OK from what I have read.
Verifying system pressure is not a bad idea either although the CT probably has a secondary regulator. System pressure should be no less than 11" of water column with 50% of appliances running, and should not go over about 12" at low draw. It will go higher when everything is off (lockup) but that's OK. (Adjustment should only be made while gas is flowing thru regulator)
Brian
