Old 03-31-2020, 12:55 PM   #1
rperrym's Avatar
2017 27' Tommy Bahama
2016 30' Flying Cloud
2014 27' FB Eddie Bauer
Hot Springs Village , Arkansas
Adhesive Recommendations
Checked on the trailer today and moved it to rotate the tires. Noticed a section of rubrail was starting to come loose. Can anyone give some recommendations on the correct adhesive or glue to re-attach this rubrail.
Rick
2017 27 Tommy Bahama
2020 2500 GMC Duramax
rperrym is offline   Reply With Quote
Old 03-31-2020, 01:38 PM   #2
"Cloudsplitter"
Rick
Just clean very well and use the correct width.
Iím done with ĎadultingíÖLetís go find Bigfoot.
Old 03-31-2020, 01:56 PM   #3
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Long long honeymoon just posted a video about replacing the rub rail stuff. Looks simple enough if you need to replace vs just getting adhesive and patching it.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 03-31-2020, 03:14 PM   #4
A W Warn's Avatar
Two Places , Sticks & Bricks
Rick
A lot of people don't realize the new trailers have adhered rub rail, not the old grooved type that an insert fits into the metal and is held by friction and compression.
I have used 3m automotive adhesive and/or or two sided automotive trim tape. I got all of it at Advance Auto. There is one adhesive for windshield and another for automotive trim. Either adhesive or the trim tape will work.
If using the adhesive: To hold the rub rail vinyl in place while the adhesive cured, I used sheet metal screws on both sides of the vinyl trim, wedged against the metal.
There's a photo here> https://www.airforums.com/forums/f45...ml#post1480059
The double sided automotive trim tape works best, IMO.
I feel homeless
Alan
Former Airstream Owner
(1973 31' Excella, 1978 31' Excella, 1987 32' Excella, 1999 30' Excella, 2000 25' Safari)
Old 03-31-2020, 04:54 PM   #5
Overkill Specialist
GMFL's Avatar
2020 30í Globetrotter
2014 23' International
Dadeville , Alabama
This one...
Instagram @Airstream_Nuts_And_Bolts
DoItYourselfRV Articles
Certified Victron Installer
Old 03-31-2020, 05:23 PM   #6
2018 30' Classic
Yeah! Iím Instagram handle is in there [emoji6]
Airstreamvagabond
BigSxyWhtGuy
Old 03-31-2020, 05:49 PM   #7
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Airstreamvagabond
Yeah Iím the Brains in there......
Old 03-31-2020, 09:35 PM   #8
2018 30' Classic
Yeah you are! [emoji1487]
BigSxyWhtGuy
Old 04-01-2020, 06:37 AM   #9
rperrym's Avatar
Thanks for the link, but I am not replacing the rub rail, just securing one part that has released from the factory adhesive tape. I'm sure it dried out but we keep the trailer in an enclosed building.
If I use the 3M tape, won't it raise the level of the part I am securing? What about gasket adhesive?
Thanks for all the suggestions.
Rick
Old 04-01-2020, 06:56 AM   #10
"Cloudsplitter"
Rick
On our Classic, the original insert has a sticky tape backing to hold it. You just need to clean the old stuff off very well from both sides. Green scotch pad with mineral spirits and/or Brakleen.👍
Insulation in the walls -- adhesive or no adhesive? wrajr Repairing/Replacing Floor &/or Frame 8 04-27-2010 09:08 PM
Clips with adhesive to re-anchor electrical mshea Electrical - Systems, Generators, Batteries & Solar 3 08-20-2005 10:25 AM
Adhesive for window gaskets Tin Hut Windows & Screens 15 10-03-2004 09:19 PM
Rubrail Adhesive and Repair Shepstream Clearcoat, Exterior Paint & Trim 3 08-09-2004 11:01 AM
dried adhesive removal, again Rog0525 Cleaning, Stripping & Polishing 8 08-18-2002 01:29 AM
