Old 03-04-2020, 07:30 AM   #1
Free range's Avatar
1993 21' Sovereign
Red deer , Alberta
adding a hitch/
Been thinking about adding an hitch underneath the rear of our AS. to slide in a bike rack that I already have.
Our As is a 21' sovereign with tandem axles so there is not much overhang past the axles so Im not worried about sway as I have read in other posts.
When I look underneath from the rear I see 2 U channel pieces on the frame on either side so I thought I could nicely bolt on a Universal RV hitch on there.
I read in other post not to do it and others that have one mounted underneath their trailer and have no issues.
https://www.etrailer.com/RV-and-Camp...ite/82201.html
1993 21' Sovereign
Free range is offline   Reply With Quote
Old 03-04-2020, 07:47 AM   #2
2018 25' International
Slidell , Louisiana
You have to be careful accepting opinions as fact. Instead a few simple statics calculations will tell you if the proposed mount location is sturdy enough to hold the static load and resultant torque plus expected dynamic loads when you hit a bump and get an impulse response.
So tell me about the u channels, size, extended length from major frame connection, what else the channels are supporting. How many bikes, how long from the proposed hitch receiver will the rack be. Hitch fastening mechanism. Pictures tell a thousand words.
Old 03-04-2020, 08:52 AM   #3
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
How heavy are the bikes + hitch parts + bike rack + add on's ?
Old 03-04-2020, 09:50 AM   #4
Free range's Avatar
1993 21' Sovereign
Red deer , Alberta
Hi
the bike rack Is about 30 lbs and 2 hybrid bikes which are also about 30lb each
all in all maybe a 100lb.
1993 21' Sovereign
Old 03-04-2020, 10:01 AM   #5
Slidell , Louisiana
Hi
Was that an echo I heard?
Old 03-04-2020, 10:08 AM   #6
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Beware of reduced ground clearance with an under-bumper hitch receiver. Airstream trailers are built low to the ground compared to other travel trailer brands, and you don't have a whole lot of ground clearance to start with. Smacking the pavement with your bike rack would transmit an impact load through the hitch receiver to the frame.
Of course, you may not have a problem if your trailer towing is mostly in flat terrain or on gentle slopes without sudden changes in slope. And with no deep potholes or ruts.
Not saying that you WILL have a problem, just that you MIGHT have one. It's just another data point to factor in so that you can make an informed decision whether to go ahead.
Old 03-04-2020, 10:46 AM   #7
batman's Avatar
1964 22' Safari
modesto , California
Options
Be careful mounting thing on the rear of the AS. As stated low ground clearance and rear-end separation are things to be aware of.
There are options for carrying bikes or other gear. A receiver on the front of the tow vehicle works great for bikes racks and cargo carriers. A roof rack for the bikes works as well. If you have a pick up truck, racks inside the bed are the best.
-Dennis
ID:	362535   Click image for larger version
batman is offline   Reply With Quote
Adding a hitch to the front of your truck - good idea or bad? Toasterlife Towing, Tow Vehicles & Hitches 31 02-08-2018 09:51 PM
Adding a Hitch system to the back of a Sport Mikeith84 Towing, Tow Vehicles & Hitches 2 09-24-2016 07:36 PM
Adding a hitch BaroloRed Hitches, Couplers & Balls 3 08-02-2011 04:32 PM
Adding a hitch to the rear of my Airstream Josie28 Hitches, Couplers & Balls 13 09-04-2010 07:41 AM
Bambi Hitch Height - Equalizer Hitch Shank campadk Hitches, Couplers & Balls 3 08-31-2006 12:48 PM
