Old 03-28-2019, 10:37 AM   #1
silvereagle2's Avatar
2014 27' FB International
Cary , North Carolina
Added trim on bottom of LP tank cover
I noticed the bottom of my LP tank cover was splitting where it came in contact with my hitch load distribution bar brackets permanently installed on the tongue. I decided to place a plastic molding strip all around the bottom edge of the tank cover and it works like a champ. If anyone is interested here is what I found and ordered from Walmart that turned out to be just the right size and thickness to press onto the edge:
http://www.walmart.com/ip/Car-Auto-L...10ft/941736493
Here are some pictures
ID:	336767Click image for larger version
ID:	336768Click image for larger version
silvereagle2 is offline   Reply With Quote
Old 03-28-2019, 01:38 PM   #2
2019 25' Flying Cloud
Hendersonville , North Carolina
Protecting propane cover
Nice fix. I used 5/16 Fuel hose on the bottom of my cover only where it contacts the frame. I also used 5/16 fuel hose on the base of the propane tanks so they do not beat up the plate they sit on. splitting the fuel line requires a stout pair of scissors and some patience. When you set the cover back in place, you have to use 2 thick washers before putting on wingnut.
uraljohn is offline   Reply With Quote
Old 03-28-2019, 02:13 PM   #3
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Very nice! I’m copying that!
wulfraat is offline   Reply With Quote
How do cords exit bottom of tank cover? Piggy Bank LP Gas, Piping, Tanks & Regulators 4 03-28-2019 08:56 AM
Does this added side trim indicate shell was taken off jwschnettl General Repair Forum 1 12-15-2018 06:57 PM
Black Bottom Trim on 84 Excella DilmoreFarms Clearcoat, Exterior Paint & Trim 0 10-01-2016 09:06 AM
Front trim along bottom--repairing wolffullmoon Ribs, Skins & Rivets 6 05-10-2015 01:27 PM
seal the bottom edge trim pieces? CindyH Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 10-23-2002 09:18 AM
