Old 06-13-2017, 10:37 AM   #1
RodNAtl's Avatar
2013 19' International
Atlanta , Georgia
Add Shut Off Valve for Bathroom Sink Lines
Need some help. I've notice that my delta faucet is leaking and I am going to replace it but at the same time i thought I could also add shut off valves to the hot and cold water lines that running to the sink.
Has anyone done this before? Any concerns?
If so, is it pretty easy and are most valve sizes standard are what size valve would I need to get.
Any help would be great.
Thanks.
Rodney
Rodney
RodNAtl is offline   Reply With Quote
Old 06-13-2017, 11:15 AM   #2
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
Here is what I did for stops, pex x 3/8" comp. angle stops since my new faucet has 3/8 supply hoses on it factory (and most do come that way now).
So then for you I would do the same stops then use a supply hose to go to your delta(I am assuming it just has 1/2" supply connections in the valve body) Then if you ever upgrade your faucet you are ready to go.
ID:	287482   Click image for larger version
Name:	new shower valve piping.jpg
ID:	287484   Click image for larger version
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Gas valve shut off help slimitch Furnaces, Heaters, Fireplaces & Air Conditioning 3 01-06-2008 04:04 PM
Black water shut off valve? '73 Sovereign Al Falcon Waste Systems, Tanks & Totes 10 05-14-2007 05:28 AM
What's this shut-off valve-Argosy MH 28' nohillgrish Plumbing - Systems & Fixtures 4 09-19-2006 05:02 AM
1986 AS 345 MH Magic Chef Shut off Valve? Jim Tyrney Stoves, Ovens & Microwaves 2 10-14-2003 02:48 PM
Shut off valve, 1992 30' Motorhome dwc Mechanics Corner - Engines, Transmission & More... 0 07-01-2002 05:50 AM
