Old 10-07-2018, 02:04 PM   #1
KLK
1966 30' Sovereign
Wimberley , Texas
AC Leaking Inside
I have a 1966 30í Sovereign AS that has was partially redone by the previous owner. Iíve always wanted an AS, and feel blessed to have this one now.
However, my A/C unit (relatively new) now leaks.
At first, it only leaked when it rained and I had it running.
Now, it leaks inside during a rain even when itís not running.
Any advice/ideas welcome.
Thank you!
Kim
KLK is offline   Reply With Quote
Old 10-07-2018, 02:37 PM   #2
ghatfield's Avatar
2006 19' Safari SE
Anacortes , Washington
Common problem
My 2006 Bambi has a similar problem. On mine, it is due to multiple cracks in the plastic pan that the AC sits in and which collects condensate and rain. I'm not sure they had this arrangement in 1966, but if they did, it means pulling the AC unit to remove the pan and then replacing it with some other sort of collection system. Dometic has a cup system, but again this may not apply to your '66. There is a ton of info on this forum on this topic since it is so common. Here is one of the threads I found especially useful.
http://www.airforums.com/forums/f44/...it-104778.html
George
ghatfield is offline   Reply With Quote
Old 10-08-2018, 06:49 AM   #3
KLK
1966 30' Sovereign
Wimberley , Texas
Thank you, George
Thank you, George, for your response. I will look at the link that you sent.
Propane leaking -- not leaking StreaminGeo LP Gas, Piping, Tanks & Regulators 8 07-26-2016 11:38 AM
1969 AC unit leaking inside billy1 Furnaces, Heaters, Fireplaces & Air Conditioning 5 09-25-2011 09:15 AM
A/C leaking water inside goswick Furnaces, Heaters, Fireplaces & Air Conditioning 5 06-25-2010 11:43 AM
Coleman Super Mach Model 6798 leaking inside AirHeadsRus Furnaces, Heaters, Fireplaces & Air Conditioning 4 06-05-2009 12:54 PM
86 coleman AC is leaking water inside 85Sovereign Furnaces, Heaters, Fireplaces & Air Conditioning 10 08-26-2007 05:44 PM
