Old 10-04-2019, 07:41 PM   #1
2014 27' Flying Cloud
Jeffersonville , IN
A/C, H/P only operating on high speed
We have a 2014 27" FB Flying Cloud with a single A/C-HP unit. It connects to a Dometic CCC2 thermostat that shows 3 available fan speeds - low, medium and high with an auto function as well. We can only get the fan to run on high regardless of the thermostat fan settings. Auto always runs on high speed.
Dometic has told me this fan can only operate on low or high. Does anyone know how to enable the low fan speed?
Beamer54 is offline   Reply With Quote
Old 10-04-2019, 07:49 PM   #2
Jim Flower's Avatar
2012 30' International
1997 25' Safari
1967 20' Globetrotter
Burlington , Ontario
Auto Fan
When auto fan is selected the fan speed will vary depending on the difference be- tween the temperature set-point and the room temperature. In auto fan the compres- sor and fan cycle On and OFF with the thermostat.
When the difference is:
8o or more
5o to 7o
4o or less
The fan operates on HIGH
The fan operates on MED
The fan operates on LOW
This is copied from the manual. Perhaps it is just the temp differential. If not try a thermostat reset.
System Reset Procedure
When your unit was installed the appropriate dip switches on the electronic control board were turned on to match your system con guration. Any time these settings are changed, a system reset will need to be done before the CCC 2 thermostat will recognize the updated selection. To do a system reset:
Make sure the CCC 2 thermostat is in the OFF mode.
Simultaneously press the MODE and ZONE buttons. The LCD will display “IniT” and all available zones.
Release the MODE and ZONE buttons.
Press the ON/OFF button to exit system set up.
I don't know if any of this will solve your problem but it is worth a try.
Jim Flower is offline   Reply With Quote
Dometic fridge only operating off L.P. troubadour1 Refrigerators 28 05-08-2022 11:35 AM
Dometic Air Conditioner only has HIGH Fan Speed Brucet45410 General Repair Forum 5 07-12-2016 12:46 PM
High Speed Aircraft Repair Tape JimWeilhammer General Repair Forum 1 09-27-2009 01:49 PM
High Speed on Interstate Tarheel Off Topic Forum 55 05-11-2006 11:39 AM
2 speed wiper switch has no low speed rdm Mechanics Corner - Engines, Transmission & More... 6 01-09-2003 09:47 PM
