Old 06-20-2021, 03:40 PM   #1
1992 29' Excella
PLANO , TX
A/C fan is not running
First time try to use my ac. It ran for a couple minutes then the fan stopped. I have to leave the ac power off at least about 10 minutes, then I can start the fan again. However it just ran a couple minutes and then stopped. What could be the problem? I have the original domestic ac. I replaced the fan run capacitor already. TIA
Xin Li is offline   Reply With Quote
Old 06-20-2021, 04:00 PM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
It might help if we knew what era AS you have.
Based on the information supplied, I'd guess your compressor is shot. That would make more sense on an older / used AS when you are not the original owner.
uncle_bob is online now   Reply With Quote
Old 06-20-2021, 04:06 PM   #3
1992 29' Excella
PLANO , TX
Hi
It is a 1992 Airstream Classic 29' . The pipes connected to compressor one is cold and another one is hot. Seems compressor still working.
Old 06-20-2021, 04:25 PM   #4
Half a Rivet Short
Hi
Next guess would be the control board.
You might want to update your member info to show the AS you have. It would save you from being pestered with "which one?" questions all the time.
Old 06-20-2021, 05:01 PM   #5
1992 29' Excella
PLANO , TX
Hi
The ac unit is Coleman Mach series
Old 06-20-2021, 06:22 PM   #6
Half a Rivet Short
Hi
Lots of places sell Coleman. Call around and see if anybody has a control board in stock.
Old 06-21-2021, 09:44 AM   #7
1972 31' Sovereign
Dry Branch , Georgia
fan motor
Sounds like your fan motor may be bad. aaait should have an internal overload that turns it off when it is pulling too many amps and overheating. As it cools the internal overload will let it start again.
Good Luck
Buckless is offline   Reply With Quote
Old 06-21-2021, 10:09 AM   #8
1988 32' Excella
Robbinsville , New Jersey
Good Luck
X2, had the fan motor seize up on AC on my 1988 AS about 4 years ago, a couple years after the fan seized on my brothers 1986 AS. Oiling the fan motor only got a couple more days out of it each of those times.
Old 06-21-2021, 12:53 PM   #9
2017 25' Flying Cloud
Woodway , Texas
Fan Not Running
If your unit's equipped with a fan start/run capacitor, it could also be that.
If you're able to get up on the roof and pull the cover, check for a very hot motor as well as a fan capacitor whose 'can' is swollen or leaking an oily substance. If the cap looks normal, the motor may indeed be at fault. Some makes have a thermal breaker imbedded in the stator windings that will open if the motor is experiencing an overheat situation.
If you can access the fan, maybe even from the inside, cut the power and try turning the fan by hand. It should rotate easily; if not, you may be able to get some oil around at each end of the motor where the fan shafts exit as a temporary fix.
If it's the capacitor, then an HVAC or motor ship, Grainger or Graybar will probably have a replacement on hand for around $15.
Hope this helps!
If
emelaich01 is offline   Reply With Quote
Old 06-22-2021, 04:08 PM   #10
1992 29' Excella
PLANO , TX
Hope this helps!
If
I replaced all capacitors already. still the same issue. most likely is the fan motor is bad. It is hard to find a replace for the one I have.
Old 06-23-2021, 08:06 AM   #11
Half a Rivet Short
Hi
At some point, replacing the A/C unit is the answer. Parts do get scarce after 30 years. The good news is that the modern units are a lot quieter than some of the older stuff.
Old 06-23-2021, 10:24 AM   #12
1988 32' Excella
When my brother's quit the correct fan was about $350 plus shipping (other AC fan motors were around $150), at the time a new AC was under $800. Not really worth fixing for the cost difference, especially since it wasn't cooling as well as it should when the fan was working.
Fridge running on LP when on Auto setting and running on Gen. Pepperpod Refrigerators 12 11-09-2020 04:58 PM
Fan-tastic Fan Motor opens but will not close hatch pamu Roof Vents, Skylights & Fans 2 09-11-2020 07:24 AM
Fantastic Fan, Dining Room Lights and Bath Fan not working Arbi Electrical - Systems, Generators, Batteries & Solar 21 07-10-2020 05:25 PM
Converter fan running... batteries fried... batteries replaced... fan still running! hollycwright Batteries, Univolts, Converters & Inverters 2 04-27-2020 03:41 PM
fridge cooling fan is on but fridge is not running hahnstead Refrigerators 5 06-24-2016 06:34 PM
