Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 08-13-2018, 08:44 AM   #1
1971 31' Sovereign
White Pigeon , Michigan
71 Sovereign Renovation
Hi everyone!
I have decided to try to keep a thread of my renovation both to get feedback and also to have a place to look back at what I did if I need to!
I bought my Airstream in March. So much has happened since, but most of it has been deconstruction. I'm going to try to remember everything that we've done so far, but I may leave things out, so feel free to ask questions and I'll answer to the best of my memory
Here are a few before pictures:
emilyweav is offline   Reply With Quote
Old 08-13-2018, 09:00 AM   #2
1971 31' Sovereign
First Steps
The first thing we did is take out all of the interior. We removed all of the dividing walls, curtains, counter, closet, etc. to get down to bare bones. As I'm sure many of you know, this is easier said than done. If I had a dollar for every hidden rivet that caused us trouble I would have a much bigger budget for my renovation!
Old 08-13-2018, 09:43 AM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
I remember doing that.... (subscribed) Click image for larger version
Old 08-13-2018, 03:16 PM   #4
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
Following.
TheGreatleys is offline   Reply With Quote
Old 08-14-2018, 06:13 AM   #5
1971 31' Sovereign
Panel Removal
Next was taking out the panels and getting rid of the NASTY insulation. I had mice trails and acorns galore in the walls and belly pan. SO GLAD I decided to take this renovation so far. I know I never could have gotten rid of the smell without replacing all of the insulation. This was a multi person project with the huge overhead panels, but it was so cool to see the progress after this. It felt like we were actually getting somewhere!
Name:	top panel.jpg
Name:	2 panels off.jpg
Name:	all panels off.jpg
Name:	back without panels.jpg
Old 08-14-2018, 06:36 AM   #6
1971 31' Sovereign
Lifting the shell
Next (and quite a bit of time later) came the BIG EVENT. This was so scary. We drilled out all of the rivets we could find, and started lifting the shell. We decided to use gantries, but instead of buying the wood for the supports, we used trees. That's southern michigan for you! It ended up working really well though and I was really happy with how it went. We struggled for a while because we couldn't get the shell to pop off. Turns out we missed a couple rivets on the tie down plate that were hidden from view. Popped those and the shell came right off! Such an awesome and terrifying experience all in one! We pulled the trailer out from under the shell and lowered it back down. keeping it level.
Name:	ready to lift.jpg
Name:	trailer removed.jpg
Name:	trailer in front.jpg
Old 08-14-2018, 07:09 AM   #7
1966 22' Safari
Fredericksburg , Texas
You’re making great progress. Pulling the shell is a big milestone. We picked up our 55 a couple of years ago north of you in Mt. Pleasant. On the way back home, every time we stopped for gas, I think a couple of squirrels or chipmunks hopped out and started heading back north. The old insulation is nasty stuff and treat it as such. Keep up the progress and post pictures as you go. Good luck, Bubba
Bubba L is offline   Reply With Quote
Old 08-14-2018, 08:15 AM   #8
rugjenkins's Avatar
1975 Argosy 28
Springville , Alabama
Great progress. Love the tree part. Except for the hole y'all cut your floor looks to be in amazing condition. Why did y'all pop the shell? Anyway love the pics. Subscribed.
Matt
rugjenkins is offline   Reply With Quote
Old 08-14-2018, 01:32 PM   #9
1971 31' Sovereign
We pulled the shell for a couple reasons. One was the back half of the subfloor. You can't really see it but it was in rough shape. So rough that we don't think we'll be able to get a template from it to match the curve. Looks like lifting the shell a little and tracing for us! it also had some rear end separation issues from what I could tell, and I wanted to add grey tanks. We also wanted to know what shape the frame was in. Thankfully, there are only a couple rough spots and mostly on the outriggers which are easy to replace. We thought that taking the shell off would just make all of those processes easier. It definitely has so far.
Old 08-14-2018, 01:42 PM   #10
1971 31' Sovereign
Shell is off!
Once we removed the shell, we moved on to completely stripping the frame. Removing the subfloor was a much harder job than I anticipated, and the temp the weekend we did it was 88-90, so we were struggling. I think it took two weekends, but we got the bellypan dropped and we were down to the frame (mostly). The bellypan material is in really rough shape. There were several questionable patches and the metal itself was corroding and starting to get holes and things, so we decided to scrap it and buy new material when we put it back together. Unfortunately I don't have too many pictures of that particular stage.
Old 08-14-2018, 01:52 PM   #11
1971 31' Sovereign
Up to Date
I believe that pretty much brings us to where we are now. This weekend, my dad installed the new outriggers I ordered to replace the ones that weren't in great shape. My mom and I worked on the panels. I decided I wanted to strip the vinyl. I have heard of the adhesive coming through and honestly I didn't want to risk sticky walls. I also think I may leave some of the aluminum bare for accent in certain places. However, this job SUCKS!!! I have had 3 people ask me today if I hurt myself because I'm so sore from squatting over those stupid panels with stripping chemical all day. We got the vinyl off of all of the biggest panels and most of the small ones between this weekend and a couple weekends ago when we started the project. Now we just need to recoat for a much shorter amount of time to get the adhesive pattern off. Thankfully that has been relatively easy so far. Hoping that continues!
Name:	frame weld 2.jpg
Name:	panel house.jpg
Old 08-14-2018, 05:40 PM   #12
Central , Mississippi
AWESUME work!!!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie(RIP) -
A honkin' long 34' named AlumaTherapy https://www.airforums.com/forums/f20...num-54749.html
and a 26' '63 Overlander, Dolly https://www.airforums.com/forums/f10...ome-71609.html
Old 10-08-2018, 12:56 PM   #13
1971 31' Sovereign
Advice needed please!
So we've gotten some more things accomplished in the last couple weeks. I'm working on removing the old window seals so we can replace them, we welded and reinforced the frame where needed, and we're now in the process of coating the whole frame in POR15. As we get closer to being able to put the shell back on, I realize I have a few questions.
I've seen people having issues with the shell fitting back onto the subfloor after a full monty. I am replacing all of the subfloor with a composite that is about half the weight of plywood and will never rot (a very exciting thing for me). Unfortunately most of the subfloor that was there before (especially in the front and back) is rotted and would be very difficult to use as a template. Without having those to use and with the shell resting on supports but not necessarily level, how do I create a new subfloor that will match the shell? I'm worried if the shell is at all out of place from being lifted and I trace it as-is, it will stay that way when I lower it onto the subfloor.
Any words of wisdom about how to go about this?
Old 10-09-2018, 07:24 PM   #14
Do you have the corners C channel? They can be a good starting point.
Old 10-10-2018, 06:32 AM   #15
1971 31' Sovereign
We do. I just want to make sure that I put it back together in a way that I can be sure the shell is on straight and not warped.
Old 10-12-2018, 09:14 AM   #16
1971 31' Sovereign
I haven't had a chance to post about my newest awesome opportunity so I thought now would be a good time. My family owns a small business related to boating and other industries where ropes need to be secured. We were invited to a pontoon show for one of the local manufacturers. While there, we got to interact with someone who was demonstrating one of the latest improvements to pontoon flooring. It's a composite flooring that is created in a honeycomb pattern. It's being used on all of the company's new pontoons, because it will never rot. Obviously with my project in mind I was very intrigued. I told him what I was doing and that I would be very interested in talking to him about the possibilities. They usually only work with manufacturers, but since they were interested in my project, they made an exception. These are the pictures of us bringing it home!
It's 3/4 inch so it's the same thickness as the plywood that was in there before. It will need to be bolted to the frame as well as sealed with an adhesive. It's about 1/2 the weight of plywood of the same thickness and will never rot or decompose if exposed to water.
I'm so excited to get it installed and very excited that I won't have to find a way to seal plywood!
Old 10-12-2018, 09:18 AM   #17
1973 25' Tradewind
Reno , Nevada
Wow! That is huge!
Phil N Lisa
Reno NV
1973 25' Tradewind
2007 GMC 2500 HD SLE Classic Crew Cab Duramax
DiHrdBowTi is offline   Reply With Quote
Old 10-12-2018, 09:33 AM   #18
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
At first I thought you were using Coosa board as your subfloor, but interested in seeing the results from your subfloor material. I was sure the OEM floors were 5/8", but I could be wrong.
If you can't make a template or accurately recreate the new subfloor from the old one, I'd suggest recreating as much as you can, remount the body, and fill in the rest afterwards.
Note: make sure you have the interior walls remounted before the snow flies, or build a snow roof over the trailer, as the outside shell will crumple under snow load without the interior walls giving it strength.
Cheers
Sidekick Tony
PS In one of your earlier pics showing the frame, it looked like one of the axle tubes was bent; now would be the time to replace axles....especially very old axles, as they have a 25 year life span.
Old 10-12-2018, 09:44 AM   #19
1971 31' Sovereign
Cheers
Sidekick Tony
I've heard varying reports as far as subfloor. When we took the old subfloor out we measured and thankfully it was 3/4 inch. If I were planning on taking it anywhere right away I would definitely replace the axles. I'm planning on keeping it parked and living in it stationary for the winter, so that particular project is being postponed for now. I have a little bit of a tight budget so I'm focusing on immediate needs first.
Old 12-19-2018, 08:44 AM   #20
1973 29' Ambassador
Lethbridge , Alberta
I am subscribing and am interested in watching how you go about the reno. We are planning the same process on our 1973 Overlander for a year from now
TinCan Don is offline   Reply With Quote
sovereign
Newb advice - 1977 Sovereign 31' renovation mkeilx2 General Repair Forum 17 03-02-2012 05:13 PM
Update on my renovation of 73 31' Sovereign nurse222 Our Community 2 08-03-2010 07:19 AM
Renovation to layout of 1973 31' Sovereign kikileg General Interior Topics 2 03-03-2010 06:47 AM
'77 Sovereign renovation thenewguy 1974 - 1979 Sovereign 18 12-14-2009 02:28 PM
Greenhorn '76 Sovereign Renovation tdturn2 1974 - 1979 Sovereign 6 06-24-2009 04:24 PM
