Old 04-13-2021, 03:06 PM   #1
2021 27' International
San Francisco , California
7-way Oops
So, this happened on our last drive. Not exactly sure how, but guessing it got caught in the hitch somehow...
Thinking about how to fix it, I was thinking just to buy a new cable and connect it it, but it disappears into the frame on the inside just under the propane tanks. Any idea where it goes from there?
Does anyone have any thoughts on whether I should...
- Replace it entirely all the way back to wherever the cable goes.
- Cut off the plug and rewire a new one on the same cable
- Install a junction box (like this) where I've shown the green box below.
https://www.amazon.com/MICTUNING-Hea..._t1_B083LR64CJ
I like the idea of adding an aux cutoff that cuts off the 12V power when the lights are not on (so we don't drain the truck battery charging our lithium batteries when parked - already did that once!), so figure I could do that in a junction box, or at the location the wire feeds to, if I can find it...
NickA is offline   Reply With Quote
Old 04-13-2021, 03:26 PM   #2
2020 19' Caravel
Ammon , Idaho
My vote is to replace just the plug.
The 12V line from the 7 way terminates in the DC distribution box, its location will vary by floor plan.
OutdoorIdaho is offline   Reply With Quote
Old 04-13-2021, 03:55 PM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard👍
X2
This also may help...POI I now use a Velcro strap instead of the zip tie.
ID:	393131   Click image for larger version
Obrigado, é hora de descansar.
Tahawus
Old 04-13-2021, 03:58 PM   #4
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
I'd replace the plug (X3). This link about how your trailer is wired might provide greater comprehension regarding the work involved in a re-wire decision.
https://www.youtube.com/embed/R2yznf5kKaI
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 04-13-2021, 04:26 PM   #5
2015 25' Flying Cloud
Schaumburg , Illinois
I agree with multiple other posts, replacing the plug seems like your best path forward. Damage is so close to the plug that length may not be impacted, and you might even have a little “slack” of cable in your path (I had some). If no slack, and length is tight after repair, there are multiple options for a pre-made 7 way extension, if you really needed that. I think pro pride even sells one but you have many options to fill that need if it came to that. New plug (only) approach sure seems like much less work (and less frustration) that trying to replace the whole harness.
1StreamDream is offline   Reply With Quote
Old 04-13-2021, 05:31 PM   #6
Thanks everyone (Heads to Home Depot...)
Old 04-13-2021, 05:48 PM   #7
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
NickA,
If plan A don’t work and plan B is cable R&R I might have a few tips. I just did a full plug to junction box cable on my 2007 Classic.
Models might have variants but I might save some grief on cable job.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Old 04-13-2021, 07:33 PM   #8
2017 30' International
Box Elder , South Dakota
For what it’s worth, I installed that junction box you linked. I removed the propane tray and installed inside the a frame. Is super straight forward and will make replacing the cord easy in the future
Labeda14 is offline   Reply With Quote
Old 04-13-2021, 07:41 PM   #9
2019 30' Classic
Charlotte , North Carolina
Replace it back to the box. Rip out the vulkem black caulk in those holes when done. It goes into the frame and them back out just inside where the a frame disappears under the trailer then up through the floor.
With a HAHA or PP hitch, get a longer cord, like 12’. Get a cold weather one so it will be flexible. I don’t like the extra connections of a pigtail because it is another point of failure. Not hard to rewire. 3 lines go to the DC dist box and 4 go to the turn, brake, reverse lights directly in my 2019 Classic. There may be.a plug to make a quick connect for the DC box wires. Had pull that pigtail off from out of the box because I couldn’t find a replacement for the 7way cord plug.
Fewer connections and splices always seem safer and more reliable to me. Plus, I like to wire things.
LilPeanut is offline   Reply With Quote
Old 04-14-2021, 04:31 AM   #10
GCinSC2's Avatar
That's some been there done that type of advice and less connections, good stuff.
FWIW my Classic took all 11' of cable.
S/OS #001
Old 04-14-2021, 07:29 AM   #11
Mollysdad's Avatar
Originally Posted by ROBERT CROSS View Post
X2
I use the same pin. It serves many purposes, it keeps the 7 way centered, it keeps the 7-way off the ground or getting caught, and it also locks the coupler!
What is your favorite 'oops' story? yukionna On The Road... 158 10-21-2017 11:37 PM
Oops, I did it again! yukionna The Pet Forum 31 02-02-2007 07:07 AM
oops remcolent Off Topic Forum 7 06-16-2005 07:07 AM
OOPS! battery not charging,water hook up spilling into reserve tank? outerbanksdeb Batteries, Univolts, Converters & Inverters 2 08-02-2004 12:40 PM
