Old 03-30-2020, 12:11 PM   #1
FPT
3-Way Fridge Not Running On Battery
2020 Globetrotter 23FBT with 3way fridge. I have my tow vehicle connected and canít get the refrigerator to run off of battery. The battery and fault buttons blink red when I switch to battery. Any ideas?
FPT is offline   Reply With Quote
Old 03-30-2020, 02:59 PM   #2
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
I recommend you test your battery voltage using a voltmeter.
TouringDan is online now   Reply With Quote
Old 03-30-2020, 04:16 PM   #3
FPT
I measured while connected to the tow vehicle and tow vehicle running.
Sunexplorer II measures 14.1
Seelevel measures 14.1
Voltmeter on batteries measures 14.01
There is no change in volts if the refrigerator is off or running battery mode.
Also, here is photo of the outside compartment. There is a wire that looks to go no where and is covered in electrical tape.
ID:	364384   Click image for larger version
Old 03-30-2020, 09:10 PM   #4
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Since you have 14v at the battery, I would call the refrigerator manufacturer, and talk to their tech support.
Does the fridge work on 120v or on propane?
Dan
Old 03-31-2020, 02:10 AM   #5
FPT
Dan
Yes, works fine on propane and 120v.
Old 03-31-2020, 05:25 AM   #6
2020 Globetrotter 25 FBT
GettinAway's Avatar
2020 25' Globetrotter
Wildwood , Missouri
I am not 100% sure mine ever works on battery. I know it runs fine on propane and electric. I always have it on automatic. I don’t think I’ve ever checked it with the truck engine running. It always goes right to propane when I unplug.
If it’s flashing, press and hold the triangle flashing button on the far right. That resets the alarm. Mine wouldn’t run on propane when we first got it. I thought I had a bad control board, until someone explained the reset/alarm button to me.
Hope you get it worked out.
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
GettinAway is offline   Reply With Quote
Old 03-31-2020, 10:34 AM   #7
FPT
Originally Posted by GettinAway View Post
I am not 100% sure mine ever works on battery. I know it runs fine on propane and electric. I always have it on automatic. I donít think Iíve ever checked it with the truck engine running. It always goes right to propane when I unplug.
If itís flashing, press and hold the triangle flashing button on the far right. That resets the alarm. Mine wouldnít run on propane when we first got it. I thought I had a bad control board, until someone explained the reset/alarm button to me.
Thanks, I was hopeful that the reset would work, but no luck. I will probably never use the battery function but would like to make sure everything is working.
Old 03-31-2020, 10:38 AM   #8
FPT
Does anyone else have a Dometic RMD8555 that they could post a photo of the outside compartment? Iím curious about this stray wire.
Old 03-31-2020, 03:04 PM   #9
egraham's Avatar
2016 28' International
Birmingham , Alabama
Have you tried flipping the store /use switch?Happened to me one time.
egraham is offline   Reply With Quote
Old 03-31-2020, 03:15 PM   #10
BAPJ
Dollie's Avatar
Puyallup , Washington
Have 2018 globetrotter I hook up while the truck is running set the switch to battery works great. Will stay on battery until I shut off the truck.
Dollie is offline   Reply With Quote
Old 03-31-2020, 03:16 PM   #11
BAPJ
Dollie's Avatar
Sorry forgot
Have the dealer fix it.
Old 03-31-2020, 03:22 PM   #12
2018 27' Globetrotter
Mooresville , North Carolina
Attached is my picture. Hard to see where all my wires run since they are behind that container. I didnít see a loose wire. However, I have an orange wire connected to the buss bar in a middle connection and your orange wire is mounted at the top. They have some labels to indicate what should be connected where but they donít really line up with anything.
For what itís worth I can manually select to use the battery while towing but it will not automatically do it.
2018 GMC Sierra 2500HD Duramax
Equal-I-zer Hitch
"Roadrunner"
GOUSC is offline   Reply With Quote
Old 04-01-2020, 08:59 AM   #13
Trnpk Crsr's Avatar
Baltimore , Maryland
[QUOTE=Dollie;2346414]Have 2018 globetrotter I hook up while the truck is running set the switch to battery works great. Will stay on battery until I shut off the truck.[/QUOTE.
I think that this is the key. The fridge runs on the 12 volt charge line from your tow vehicle. It does not run off your house battery. If it did, the battery would be dead in minutes.
Hook your trailer up to your tow vehicle and start the engine. Then see if the fridge will switch to 12 volts.
Cheers,
John
Trnpk Crsr is offline   Reply With Quote
Old 04-02-2020, 10:01 AM   #14
FPT
The photo helps a lot but the wire colors donít seem to match up. Thanks for posting that. Guess Iíll be making a stop at the dealership after the world is done coming to an end.
Old 04-02-2020, 10:04 AM   #15
FPT
Thanks for other suggestions as well. No luck toggling the store/use switch and Iím hooked up to the tow vehicle while trying to switch the fridge to battery.
Old 04-02-2020, 01:50 PM   #16
2019 27' Globetrotter
Denver , North Carolina
FPT
I have a 2019 27' GT with the Dometic 8555 refrigerator. You do not need to be hooked up to your TV to run the refer on 12 volt, it is powered by the trailers batteries. Your TV keeps the batteries charged.
The manual states that if the 12v led and the fault led on the control panel are both flashing the refer either has no 12v supply (blown fuse?) or the supplied voltage is to low. On my GT there are 12v fuses in the panel below my refer but none of the fuses are labeled "refrigerator" so it is either mislabeled or the fuse is in some other location.
My wiring is the same as GOUSC's, not like yours. I would use a multimeter on the wires on the right side of then connector block to see if any read 12 volts. I do not have the "extra wire" in your photo in the wire loom entering the refrigerator compartment.
I would also send the pic you took Airstream tech support and ask them what's up with the different wiring and ask where the fuse is located. PM me if you want a copy of picture of my wiring. Note the black jumper wire missing from your set up.
Good luck let us know what happens.
Dave S
link2dks is offline   Reply With Quote
Old 04-02-2020, 07:01 PM   #17
FPT
Thanks, Iíll fire off an email to Airstream, Dometic and my dealer and update this thread on what I find out.
Old 04-03-2020, 05:58 AM   #18
2018 25' International
Slidell , Louisiana
The D+ terminal is an optional input signal intended to be wired to the alternator on motor coaches. With that signal connected the refrigerator will automatically switch to 12V when ever the alternator is providing voltage. Without it connected, your refrigerator has no way to detect that your tow vehicle is present so you must manually switch it to 12V.
As another poster indicated it was probably a coincidence you have a fault unrelated to the fact you had the tow vehicle connected. You didn't indicate clearly if you have ever had it successfully running in 12V mode. So as suggested clear the fault and try 12V mode again, since you don't have the +12D wired you will not need the tow vehicle.
I looked at the online Manual (search for it), it also describes the need to clear the fault before you can select 12V again.
It would be nice for you to run the refrigerator on 12V while towing. It draws 10-14A while cooling and about 1 Amp when resting so it will consume power from the batteries pretty quickly while running. Don't use the battery only to cool the refrigerator and once cold and fairly full, if you don't open the door, you could go 12-18 hours on batteries with no trouble.
Brian
BayouBiker is online now   Reply With Quote
Old 04-03-2020, 08:02 AM   #19
Airstream Ambassador
AirstreamInc's Avatar
Jackson Center , Ohio
Hi FPT,*
Please send us a direct message with your contact information and the last 6 digits of your VIN so we can learn more and share it with our Customer Service and Technical Support team. We look forward to helping you get this resolved.
You can also reach Airstream Customer Service and Technical Support at*customersupport@airstream.com
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
AirstreamInc is offline   Reply With Quote
Old 04-04-2020, 03:35 PM   #20
FPT
Unfortunately, clearing the fault does not permanently fix the problem.
3-way to 2-way fridge conversion (Interstate van) InterBlog Sprinter and B-van Forum 5 07-06-2019 10:08 AM
Dometic fridge fan running while fridge is off fclewis Electrical - Systems, Generators, Batteries & Solar 4 10-17-2018 08:30 PM
fridge cooling fan is on but fridge is not running hahnstead Refrigerators 5 06-24-2016 06:34 PM
Making a 2-way Fridge into a 3-way Fridge? Bunkroom Refrigerators 18 06-03-2014 04:37 PM
What is 2 way vs 3 way fridge? Astrodokk Refrigerators 12 06-01-2005 03:33 PM
