Old 05-16-2021, 03:45 PM   #1
2019 23' Flying Cloud
Port Colborne , Ontario
2019 23' FC FB Dinette Table
Folks,
We purchased a slightly used 2019 FC with FB.
The dinette table leaves a lot to desire. Our old 97 Safari had a very stable fold out table and the new 2019 has a pedestal table that can be lowered to make up a bed.
The table is very unstable and I can see that there is a lot of "play" in the gliders that allow for the table to move inwards and outwards from the back of the sofa.
I suspect the previous owner may have put excess pressure on the edge of the table as it is not level at all. It is very loose and can tilt up and down with a slight touch.
I am wondering if anyone has had this sort of problem and if there is a remedy.
The glider track is very poor quality and has a lot of play and also it is only secured on one end of the track.
The pedestal seems adequate. I am thinking a whole new high end set of tracks and securing the table.
Anyone have any suggestions?
Keith S.
Keith S is offline   Reply With Quote
Old 05-16-2021, 05:05 PM   #2
2018 30' Flying Cloud
Anchorage , Alaska
We simply got rid of the slide tracks on ours and screwed the tabletop directly to the pedestal. It’s very solid now. We don’t plan to ever convert it to a bed.
AKNate is offline   Reply With Quote
Old 05-16-2021, 05:53 PM   #3
Dennis C's Avatar
2020 23' International
Evergreen , Colorado
Is the pedestal unstable, or just the sliders? The pedestal can be tightened up to make it more stable, but I'm not sure about the sliders.
Dennis
2020 International Serenity 23 FB "Sparkle Plenty"
2018 GMC Denali 1500 Crew Cab 4x4
Airstream Club International #2805
Dennis C is offline   Reply With Quote
Old 05-16-2021, 07:25 PM   #4
s1000pre's Avatar
2021 30' Flying Cloud
2020 25' International
minneapolis , Minnesota
Keith,
I had a 2021 FCBunk same issue...here is a fix:
https://www.airforums.com/forums/f44...ix-220892.html
- Stewart
s1000pre is offline   Reply With Quote
Old 05-16-2021, 09:12 PM   #5
PKI
PKI's Avatar
Walnut Creek , California
There are a lot of different solutions, but the fix is to lock the table in place. The slide lock does not function intuitively. You have to apply a bit of pressure to get the tab to lock fully in place. When you get it right, it makes a difference.
The other solution that has been employed is replacement of the OEM slides with high quality heavy duty units.
Getting your table right is key to being happy with the FB. Pat
Old 05-17-2021, 09:32 AM   #6
Mad Scientist
2017 23' Flying Cloud
CULPEPER , Virginia
FC FB dinette table
I replaced the entire table! I thought it was poorly sized for normal people to sit at the table. I built a new table out of 11 ply cabinet birch and then put high quality drawer slides ( vertically- like they're designed to be used- not horizontally). The result is a very stable table- can still make dinette into a bed. Added a good latch system which allows the table to be adjusted back and forth in 1" increments.
samletz is offline   Reply With Quote
Old 05-17-2021, 10:05 AM   #7
Anchorage , Alaska
I eventually replaced the entire table too. I didn’t mind the size at all and just copied it on the new table, but I didn’t like the plastic look and feel of the Formica. I made the new tabletop out of Jatoba.
Installation Instructions - Replacing dinette table with floor mounted pedestal table dlykken General Interior Topics 13 03-22-2020 02:16 PM
Airstream dinette & table - 2019 Flying Cloud wkaren3 Airstream Classifieds 0 01-06-2019 10:41 AM
entire dinette (table, seats and cushions) and flip down table furtrader Airstream Classifieds 0 05-25-2017 05:20 PM
Dinette Table (table top and 2 legs) helluva Airstream Classifieds 0 04-25-2016 12:49 PM
credenza, dining table, small table for top of credenza, small table from other side of trailer janeinthemtns Airstream Classifieds 1 09-25-2014 05:24 PM
