07-30-2017, 10:22 AM
2017 30' International
Broomfield
2017 30' - tongue jack mount - is this normal?
I just noticed that my jacket slightly tilted versus perfectly vertical.
Upon inspection I noticed that whoever installed the tongue tack at the factory placed a lock ring between the jack mountain plate and the trailer frame mountain surface. This is causing the jack mounting surface not to be flush with the trailer tongue surface.
My 2008 25' never had this single lock washer.
The other two bolts holding the jack to the frame do not have this washer and are more or less flush.
Not to mention it looks like they cross threaded one of the other bolts. Seems like a sloppy install and I wanted to check if others have this lock ring in place or not on the forward mountain bolt.
See pictures.
Thanks airforums!
07-30-2017, 10:52 AM
Reads a lot
Titusville
For what it's worth, Mine does NOT have the washer. All 3 of my bolts are washerless.
Lauri
She Believed She Could so She Did.
07-30-2017, 11:48 AM
Broomfield
Thanks - seems odd to me
07-30-2017, 02:05 PM
Chelsea
, Maine
I had to change my jack when it quit working. It had one star washer under one corner. My understanding is that it's to provide a good ground.
2023 Entegra Odyssey 26M
2017 FC 27FB
2017 F250 Lariat Crew Cab 6.2L
Equal-I-Zer 10K/1000
07-30-2017, 06:58 PM
Broomfield
ahhhhh..... that would make sense.
07-31-2017, 12:10 PM
2016 27' Flying Cloud
Olympia
"I had to change my jack when it quit working. It had one star washer under one corner. My understanding is that it's to provide a good ground."
As it happens, my jack crapped out yesterday while returning from an AS Rally. When I got home, I removed it & found the one star washer, which I inferred was for an electrical ground (although it was heavily rusted).
Richard Wills, Olympia, WA --- WBCCI 8873, WL7Z
"Aurum": 2018 Ram/Cummins 3500
"Argentum": 2016 AS FC 27 FB
RIP "BigDog": M Harlequin Great Dane, 150 lb
"St. Rocco": M Black Great Dane, 150 lb
07-31-2017, 12:24 PM
2012 25' Flying Cloud
Battle Lake
Yes, the washer ensures a good ground for the tongue jack motor. You most probably have tried this, but if the washer connection is badly corroded, clean it up and try the jack again. The corrosion may have created enough voltage drop (resistance) where it could not lift the trailer tongue.
Doug and Cheryl
07-31-2017, 08:19 PM
Cave Creek
See pictures.
Thanks airforums!
Mine is exactly the same - and the jack bubble is thus not showing level when the trailer is level
Pete B55
2017 Classic
2017 F-250
07-31-2017, 08:29 PM
2011 30' Flying Cloud
East Jordan
, Michigan
I recently changed out my jack. New one came w 3 star washers and was level after install because I used all 3. 3X ground as well. Suggest adding 2 star washers.
07-31-2017, 10:32 PM
2016 28' International
Redmond
You can't use 3 washers since the Jack will not correctly align with the support bracket below it. I believe Airstream does this so there is tension between the ram and tube assembly on one side, this tension prevents the trailer from rocking back and forth when the trailer is resting on the Jack.
How do I know this?
I thought the same thing when I replaced my jack:
http://www.airforums.com/forums/f44/...ed-164742.html
So I replaced the support bracket and perfectly aligned the top and bottom holes, now my trailer rocks a bit more when camping. I should have dropped by the Airstream dealer so I could notice all the trailers are like that.
I suppose it's also possible because Airstream can't weld and they use the washer to provide alignment between the top and bottom plates.
You can find the Atwood installation instructions below, there are supposed to be 3 star washers on the jack flange not below it.
http://www.atwoodmobile.com/manuals/...2011.21.07.pdf
08-01-2017, 06:30 PM
1977 Argosy 28
Euless
I just bought a replacement jack and the instructions said it was to insure a good ground. There will line up ok with one washer or 3.
Past President, Vintage Airstream Club, WBCCI # 7291
1977 Argosy 28 Center Bath (CA made) and 2015 Ford F250 6.7 diesel. Used to own 1978 Argosy Minuet 6.0 and 2013 Toyota Tundra
