Old 05-07-2021, 09:11 PM   #1
2021 22' Caravel
Bozeman , Montana
2-way refrigerator/microwave not working on battery
Hi,
Just picked up a '21 Caravel a couple weeks ago and heading out for a trip tomorrow. I've just discovered that the 2-way refrigerator and microwave are not working on battery power. They both work fine when plugged into shore power. I've flipped all the breakers to no avail.
Does anybody have any ideas what might be wrong?
Thanks for any help.
Brian.
Brian R. is offline   Reply With Quote
Old 05-07-2021, 09:54 PM   #2
2020 19' Caravel
Ammon , Idaho
The microwave will only work while plugged in; battery is not an option.
Did you "turn on" the battery with the Use/Store switch while attempting to run the fridge?
OutdoorIdaho is offline   Reply With Quote
Old 05-07-2021, 09:57 PM   #3
2006 28' Safari SE
Raleigh , North Carolina
Are you new to RV type systems? I don't know everything about new models but is your 2 way fridge 110v and propane? If so its not going to run on battery power, needs propane when not plugged in. Also, my '06 microwave didn't come wired to run off the inverter/converter. (open to suggestions for a work around, PM me if someone has done this)
Dmccloy is offline   Reply With Quote
Old 05-07-2021, 10:40 PM   #4
mefly2's Avatar
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town , *** Big Sky Country ***Western Montana
Is your microwave and fridge connected to your inverter? That would not be common.
2015 25' Eddie Bauer Int. / 2020 Ford Expedition 3.5 eco B
2019 Chev New Silverado 1500 6.2 V-8; equalizer hitch
AIR# 44105; formerly WBCCI 2015.1
Old 05-08-2021, 08:37 AM   #5
2021 22' Caravel
Bozeman , Montana
it's a 2-way fridge
I understand that the microwave will only work on AC. But the fridge is 2-way and should work both on AC and DC. I assume that when I disconnect shore power that it should automatically switch to battery.
Old 05-08-2021, 08:41 AM   #6
fran&frank's Avatar
2016 27' Flying Cloud
Hartsburg , Missouri
Do your overhead lights work, if so that tells you you have 12 volt power and the battery disconnect switch is on. Your fridge may or may not automatically switch to 12 volt, find the manufacturers instructions in your owners packet of information. --Frank
Frank & Fran
2016 27' FC FB with 600 W solar
2016 Ford F150 EcoBoost
Equalizer Hitch
fran&frank is offline   Reply With Quote
Old 05-08-2021, 09:13 AM   #7
2005 19' Safari
2007 23' Safari SE
Onekama , Michigan
Like mentioned. A 2 way fridge is propane and AC only. There are some 3 way fridge's but one has to be very careful not to kill their batteries. Yours is propane and AC only
Gene T is offline   Reply With Quote
Old 05-08-2021, 09:13 AM   #8
2021 33FB Classic
Green Valley , Arizona
So I have a new 33 classic. I had all the same questions while it was being built. What is going on is your refrigerator is a 2 way which means 110 or propane. I was very confused at first but in the end you, I and many others were mixed up on what that means. What in the end I was thinking was a three way refrigerator. This is 12 volt, 110 and propane. In the end I put in a large dolor bank of batteries 4 and they required the convection oven and refrigerator so they will work off the inverter. But as I found the refrigerator is a power hog and with 4 lithium batteries I can only run the refrigerator for about 4 hours. We did this so we can keep the refrigerator on going down the road. I hope this helps
herri61 is offline   Reply With Quote
Old 05-08-2021, 09:20 AM   #9
Half a Rivet Short
Carlisle , Pennsylvania
Hi
No stock AS (motor home or trailer) will run the microwave off the battery. The inverter simply will not put out that much power. If you *had* a bigger inverter, then the stock batteries in most (but not all) AS RV's would not do a good job.
"Two way" on a fridge can mean multiple things:
1) It will run on propane and 120V
2) It will run on 12V and 120V
Yes, this is confusing. The terms "absorption" and "compressor" are a whole lot better for working out what you have. If you have an absorption fridge, you will need to have propane hooked up and the lines purged for it to fire up. If you have a compressor fridge and it does not run on 12V, then there is a fuse or wire issue somewhere.
Old 05-08-2021, 09:49 AM   #10
2021 27' Globetrotter
Tallahassee , FL
Usually 2way means shore power or Propane.
Kawboy01 is offline   Reply With Quote
Old 05-08-2021, 10:34 AM   #11
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
From the 2021 Caravel owners manual online:
"Your Caravel is equipped with Nova Kool 2-Way (12V,
120V) refrigerator. Review all refrigerator literature
supplied in your owner’s packet or stored in the
refrigerator prior to operating
Operation
The refrigerator operates on 12-volt current from the
battery or on 120V shore power"
Any other DC circuits not operating?
And from the fridge mfgr, https://www.novakool.com/guides-and-manuals lots of online docs and troubleshooting.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook. BMV-712
GCinSC2 is offline   Reply With Quote
Old 05-08-2021, 06:50 PM   #12
2021 33FB Classic
To follow up. With my major solar upgrade I added a 3000 watt inverter with four Lithium batteries. Your fridge does need 12v to operate the propane system. But it will Not run on 12 v unless you do an upgrade and they wired the convection oven and the refrigerator to the inverter. So both items will work on the inverter. Without the inverter it is propane with the assistance of 12 volt or shore power. So again I just picked up my Airstream a month ago. You can call Tampa Airstream and they will confirm this.
Old 05-08-2021, 06:59 PM   #13
Long Island , New York
Exclamation
Amazing the diversity of opinions here, without really knowing the specifics of the OP’s trailer!
Good move Gary . . . thanks.
Operation
Gary
Let the music lift you up . . .
Old 05-10-2021, 06:16 AM   #14
Wondering if you [OP] have had any luck getting the fridge going, and whether your batteries were well-charged?
What is your monitor reporting for battery voltage? [after waiting an hour since disconnecting shore/generator/solar power]
FYI the Batteries etc. sub-forum might have some helpful threads IMO:
https://www.airforums.com/forums/f449/
Old 05-10-2021, 06:55 AM   #15
Mikebrady62's Avatar
2019 27' International
Rogers , Arkansas
2-Way Here Does Not Mean Propane
Operation
Gary
Brian R
I am hoping you have this figured out by now.
Most AS are AC/Propane. The newer AS do not have the propane option for the refrigerators. I'm not sure I would want this but I'm sure there arepeople that do like it this way.
Mikebrady62 is offline   Reply With Quote
Old 05-12-2021, 10:10 AM   #16
1968 26' Overlander
Miami , Florida
Novacool 2 way
Operation
Gary
I am not trying to hijack the OP thread, but I also have a nova cool two way fridge that I installed in a 68 overlander. The other day my wife told me that I did not need to defrost the fridge because it had taken care of itself. Turns out the 12 V breaker got bumped and tripped. But the trailer was still plugged in to shore power. What I'm wondering is if the in Nova Cool needs at least some 12 V power to run its circuitry and decide to switch back-and-forth between 12 V and 120 when available. A
Does anybody have a thought on that?
TurkeyRun is offline   Reply With Quote
Old 05-12-2021, 10:26 AM   #17
JEB
2021 23' Globetrotter
Northern , Illinois
Why would you say that? If you have a ‘21 Globetrotter, then your refrigerator is a Nova Kool compressor-driven refrigerator, same as mine. It operates on 110v and 12v only. It does not operate on propane.
JEB is offline   Reply With Quote
Old 05-12-2021, 11:26 AM   #18
JEB
Northern , Illinois
If you have a Nova Kool—and it sounds like you do—the switchover should be automatic. Have you checked the 12v fuses to make sure none is blown? Have you made sure the battery disconnect is in the on position?
Old 05-12-2021, 03:32 PM   #19
2018 30' Classic
Jacksonville , Florida
Two way refrigeration.
Refrigerator on propane uses 12v controls. That means you have to have both the propane and the battery on.
Think about it. It maintains a temperature. To do that the controls monitor temp and turn on the burner when it needs to cool down the unit. The 12v lights the burnet. It also gives you that temp reading indicator. When cold enough it turns off the burner.
On 110vac the 110 vac gives 12v power to run the controls. The "burner" is a 110vac resistance element.
Overstreet is offline   Reply With Quote
Old 05-12-2021, 05:18 PM   #20
Exclamation
Unless the OP's 2021 Caravel fridge does not use propane at all?
See Post #11:
Operation
Gary
2020 Classic 33 Microwave Not Working no_worries 2016 - Current Classic (all lengths) 8 11-11-2019 07:51 AM
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 10:04 AM
Help! Battery not charging, outlets not working when plugged in AirGal04 Electrical - Systems, Generators, Batteries & Solar 9 06-06-2014 09:15 PM
2 way or 3 way Refrigerator? New or Old? prairieschooner Refrigerators 10 09-13-2006 09:45 AM
Microwave not working ViewRVs Airstream Motorhome Forums 4 08-28-2002 02:08 PM
