Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > General Repair Forum
Old 07-31-2021, 05:19 PM   #1
2017 25' International
Moncks Corner , South Carolina
12v power
Hello fellow Streamers!
I am wanting to add a 12 VSirocco fan above the TV in our 2017 International 25 FB to circulate some air in the dining area. I would like to know what is the closest source of constant 12 V power that I can pull from. I installed one in the bedroom and pulled from the light switch and we love it. i’m not an electrician but I am learning to be but would rather run it past you pros
As always your advice is always appreciated
BetterBoat
Betterboat is offline   Reply With Quote
Old 07-31-2021, 07:45 PM   #2
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Since this is "never twice the same way" Airstream, even with the same trailer, somebody still might guess wrong.
The good news is that the light switches (as you have found) are a good source of power. Since you have lights just about everywhere, routing to one of them normally is the way to go.
The other advantage of most of the light switches / wires is that they are mostly easy to get to. Pulling out the fridge to get to a "close" wire .... not so easy.
12v
Victron Orion 12V to 12V converter mikedebi Generators & Solar Power 53 08-23-2022 11:04 AM
Can I replace 12V AGM battery with 12V deep cycle battery? iainmcc Batteries, Univolts, Converters & Inverters 10 06-06-2020 08:05 AM
12V Power Plug in for 12v T.V. Undertaker Electronics & Connectivity 12 09-10-2016 08:53 AM
LCD Tv has a 12v converter... Can I use it on 12v? Keyair Audio, Video & TV 6 05-11-2010 03:40 PM
Can I Replace 12v light with AC fixture and still work off 12v M&M CAPECOD Electrical - Systems, Generators, Batteries & Solar 5 07-11-2005 10:58 AM
