Old 11-04-2018, 04:31 AM   #1
2000 30' Excella
Toledo , Ohio
Tuson Sway Control ?
Does anybody use the Tuson Electric Sway Control on their Airstream ?
I was at Jackson Center last week and talked to a person that has one on His new 33' and I noticed they sell them there also . he claims it works very well ,They cost around $550. + install quite a bit cheaper than a Hensley or ProPride . Just wondering what you all think .
hope to hear some opinions .
Thanks Les Grace
woodfox45 is offline   Reply With Quote
Old 11-04-2018, 05:05 AM   #2
Andrew T's Avatar
2019 27' Tommy Bahama
London , Ontario
If you go to our website
https://www.canamrv.ca/ look under towing videos “electronic sway control “ You can see a test we did with the Tuson unit.
It will likely never be needed but that one time it is will make the difference.
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 11-04-2018, 05:11 AM   #3
Vintage Kin
Fort Worth , Texas
It’s not a substitute. A Hensley-patent hitch will keep the TV out of trouble. The TUSON device makes anti-sway a belt & suspenders proposition.
Andy’s test (posted here also) is a must read.
Which is better? A sway control hitch or a vehicle with sway-control? Lucky Strike Tow Vehicles 27 08-13-2015 05:34 AM
Does Dodge RAM's Integrated Sway Control Work Well With Friction Sway Control? interstateflyer Towing, Tow Vehicles & Hitches 9 08-13-2014 10:05 AM
DirectLink Brake Controller by Tuson switz Towing, Tow Vehicles & Hitches 12 05-25-2014 07:42 AM
Sway bars and sway control phibbs Towing, Tow Vehicles & Hitches 1 09-03-2012 05:48 AM
L-pins are grinding against the sway bars on my Equal-i-zer sway control hitch Simoneau Hitches, Couplers & Balls 9 06-20-2009 08:28 AM
