Update: Most important is that I went to my Airstream dealer. Toyota Tundra brake controller is fine. 12 volts and 10.5 amps output at the connector.
The brakes seem to check out too when connected to the mechanic's tester/battery source according to the AS mechanic. But when connected to the Toyota, the AS brakes are very weak even though adjusted fairly tight. The mechanic recommends a brake inspection. He agrees that the brakes should be much stronger when connected to the Tundra.
So, it is still a mystery. I called Toyota corpoate and they have no TSB (service bulletin) on the 2021 Tundra controllers.
So, as Gary suggested, maybe the connectors dont marry well. Or maybe the brakes have a problem not obvious to the mechanic.
I'm going to call Airstream corporate and see if they have any experience with this. I also have a new blade type connector on order. I'm suspicious of the AS connector at this point. After ruling that out, we'd have to pull the hubs and check everything. The trailer has only a few thousand miles, 9 months old.
I'll post any solutions. Thanks to all for the input.
Originally Posted by GCinSC2
Brad,
The TSB https://static.nhtsa.gov/odi/tsbs/20...32385-9999.pdf applies to 2016-2017 Tundra's and JHH's is a 2021. Hopefully the old update has long been addressed but updates to software are something that modern vehicles, phones and such make us deal with.
It's a good idea for things to check off of the list.
Hopefully JHH will get some feedback to this thread.
Being brake aware and such is a real good thing.
Gary
