Old 04-23-2024, 11:07 AM   #1
2021 20' Caravel
Poway , California
Suggestions for a better brake controller
I have an Echo brake controller I use with my 20' Caravel. It uses the "OneControl" app on my iPhone to operate the brakes via a wireless connection. This setup came with the Caravel when I bought it.
For the first few months of use it seemed to be OK but it did seem like the trailer brakes may have been a bit light when braking, but I was gradually increasing the settings. More recently there seemed to be a change in ownership and the iPhone app was changed to use the OneControl app. Now the trailer brakes are very erratic and grab when even the lightest brakes are applied and then release very suddenly. The result is a jerky response that feels somewhat unsafe. I have tried lots of settings with little change.
I am concluding that this system needs replacement. I would appreciate any suggestions about better systems I should consider.
dclark064 is offline   Reply With Quote
Old 04-23-2024, 11:29 AM   #2
19’ Bambi Flying Cloud
BikeCamper's Avatar
2017 19' Flying Cloud
Airstream Coach - Other
Husqvarnia , Husqvarnia
What is your tow vehicle?
I installed a RedArc TowPro Liberty in our TV and have been very happy with it. The brains/module gets installed up out of the way under the dash. The control head is just a small lighted dial that can fit almost anywhere on the dash that is conveniently within reach. It works very well and was very simple to install.
Whatever brand/model you end up choosing, I would steer you to a hardwired unit rather than a wireless/app-based version. Positive control of the trailer brakes is too critical to leave to a wireless app connection, imo.
2017 Bambi 19 Flying Cloud
BikeCamper is offline   Reply With Quote
Old 04-23-2024, 12:16 PM   #3
2021 20' Caravel
Poway , California
I am towing with a BMW X5.
Your suggestion looks good but I have no idea how to access the necessary connections. I may call the Airstream dealer and see what they install.
Old 04-23-2024, 12:49 PM   #4
BikeCamper's Avatar
Many vehicles are “pre-wired” for installation of a brake controller. To find out if yours is, consult your vehicle owners manual. If yours is pre-wired, it’s just a very simple matter of ordering your vehicle-specific harness and plugging the harnesses together.
Old 04-23-2024, 01:40 PM   #5
2021 30RB Classic
2023 27' Globetrotter
Sproat Lake , British Columbia
I usedone on my Range Rover, jumped in and had to re-install the app. Also noticed really jerky braking, but reduced the output.
Looks like there is max output and sensitivity adjustments. I haven't tried it since, I got flat tire on the Rangie that day, swapped back to the RAM 1500
https://assets.curtmfg.com/masterlib.../51180_INS.pdf
FS 2023 Globetrotter
(Vancouver Island, B.C.)
FMSports is offline   Reply With Quote
Old 04-23-2024, 01:55 PM   #6
JeffKim's Avatar
2023 25' Globetrotter
2021 16' Bambi
Forest Lake , Minnesota
We have the Tekonsha Prodigy P3, which I think a lot of people use and if I recall they were selling it at the Jackson Center service center. With our Audi Q7 the towing connection was under the front floor on the driver's side (I had to pull off some panels and dig around). Tekonsha sells an adapter for the Q7. If you have factory tow package, I'd guess it's the same with BMW. If it didn't come with factory towing then you would have to run the wiring and maybe have a trailer shop do it.
We started out with the Echo, but didn't like that it tied up the phone and you have to leave the app up in order to activate the brakes to dampen sway if it happened (never did). The P3 has worked very well for use, no issues.
2023 Globetrotter 25FBT "Curly"
2017 Audi Q7 3.0T
WBCCI 6343
JeffKim is offline   Reply With Quote
Old 04-23-2024, 03:50 PM   #7
aftermath's Avatar
Spokane , Washington
I also have a P3 and it has worked just fine, better than fine actually. I do not like the idea of having to be connected via WiFi for the brakes on my trailer. I like the idea of being hard wired in. Most, if not all, new trucks come wired for brake controllers. I simply purchased an adapter for my tundra and plugged it in. Easy Peasy.
aftermath is offline   Reply With Quote
Old 04-23-2024, 07:28 PM   #8
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 194
RE: Suggestions for a better brake controller
Greetings dclark064! Welcome to the Forums!
I will admit to being one who sticks with a product indefinitely when it works well for my use characteristics, and the Hayes Energize Brake Controllers have been exceptionally reliable with performance that I have been able to count on since 1983. My current unit dates from the mid 1990s, but continues to perform beautifully under all conditions.
The only sad thing is that, on the new models, they have discontinued the optional remote control panic button that allowed the panic button to be handy to the driver -- mine is draped over the automatic shift lever and is far easier to reach in an emergency than the control box mounted on the dash. I haven't had to use the panic button since I have been towing my Airstream and Argosy (1995 and after), but it was needed often with my box style travel trailer that I owned during the 1980s. I am hoping that my current unit lasts as long as I am able to travel.
Good luck with your investigation!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
overlander64 is online now   Reply With Quote
Old 04-23-2024, 08:00 PM   #9
knunut's Avatar
2023 16' Basecamp
Chgo. N.W. Burb's , Illinois
Redarc
Totally agree. Had the Echo. Not reliable .
knunut is offline   Reply With Quote
Old 04-23-2024, 10:05 PM   #10
2019 22' Sport
High River , Alberta
Not every vehicle is pre wired. However, any competent RV tech can install a brake controller.
There are four wires: power direct from the battery with a resettable circuit breaker; a wire that connects downstream of the brake light switch under the dash (and will backfeed that circuit to illuminate the brake lights if you activate the manual switch on the brake controller); the output wire that connects to the trailer brakes via the 7 pin connector; and, of course the ground wire.
AlbertF is offline   Reply With Quote
Old 04-23-2024, 11:44 PM   #11
2021 20' Caravel
Poway , California
AS Service and BMW service
I called the local AS service center and they told me they don't install brake controllers and told me to contact BMW. BMW service seemed clueless about brake controllers. I am going to call them again and escalate my service request. I have found several posts on the internet about DIY installs of the brake controllers and my X5 is supposed to be prewired. The problem is that the connector is special and all the DIY installs need to cut off the connector and install one that is purchased. Not something I want to do. I'm going to press BMW service about it.
Anyone have BMW install a brake controller?
Old 04-24-2024, 12:47 AM   #12
2002 19' Bambi
Lafayette , California
We also had the low speed grabbing with the Echo and found it dangerous. We switched to a Redarc and all is good.
Tim
Tim A. is offline   Reply With Quote
Old 04-24-2024, 07:56 AM   #13
JeffKim's Avatar
2021 16' Bambi
I know our Audi dealer knows next to nothing about towing and brake controllers. We took our Q7 in for service and they asked if the brake controller was a radar detector. I'm guessing BMW is not all that familiar with them as well. A trailer shop might not know BMWs but should have a better understanding of what needs to be done. Also, maybe try googling and see if there are any YouTubes on how to do it. There was one for our Audi.
2017 Audi Q7 3.0T
WBCCI 6343
Old 04-24-2024, 09:53 AM   #14
BikeCamper's Avatar
In this video, the guy mentions that BMW offers a factory TBC kit for the X5 but he builds his own because it was back-ordered:
https://youtu.be/nq6La5Fut4A?si=AEdzhiaekt2AUs0S
Old 04-24-2024, 10:07 AM   #15
2012 23' FB International
Woodstock , Ontario
Tekonsha P3. Hands down
Have had Three with different trailer set-ups. The on;y better controller I've had was the Jordan but no longer made
JCWDCW is offline   Reply With Quote
Old 04-24-2024, 10:50 AM   #16
Icy
2010 22' Sport
Sarnia , Ontario
We pull a 25’ Lance 1995 and use a TOW-PRO ELITE ELECTRIC BRAKE CONTROLLER. Easy to install, no unsightly big box and work great. Highly recommended.
Icy is offline   Reply With Quote
Old 04-25-2024, 01:58 AM   #17
Icy
2010 22' Sport
Sarnia , Ontario
Call these people in California (760) 996-5764
They install redarc products.
2575 Progress St, Vista, California 92081
Info@BasilsGarage.com
Old 04-25-2024, 10:37 AM   #18
Woodstock , Ontario
I googled to find the prewire on our 2016 Benz and found it buried under the dash as per the video
I bought the correct cable on Amazon
Took a while as it had to come from Tekonsha but after some initial confusion the adaptor did fit the vehicle harness
Try searching for your BMW brake controller installation
Old 04-25-2024, 11:20 AM   #19
BigBlu
2021 25' Flying Cloud
Geneva , Illinois
Images: 8
Redarc all the way. Easy install and easy to use. Looks like it is OEM..
BigBlu is offline   Reply With Quote
Old 04-25-2024, 11:37 AM   #20
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
We use the Tekonsha Prodigy P3
no issue after 6 years of use
2023 25' FB FC, hatch, Queen, 30A, 1AC, Awning pkg, Convection uwave.
Multiplus 12/3000-50, 700A Lion, MPPT 100/30, Orion-TR 30, Cerbo GX,GX touch 50, Lynx distributor, dual BMV-712, smart shunt 500A&1000A, RUUVI temp/humidity sensors
NCR , Ontario, VE3HIU since 1978
WBCCI# 21212
waninae39 is offline   Reply With Quote
Which would you rather? Better brakes, better hitch, or better wheels/tires? bjmckernan General Repair Forum 30 07-17-2016 06:47 AM
Brake lights, brake controller not functioning adwriter73 Brakes & Brake Controllers 17 01-16-2014 09:37 AM
Better brake controller for pre-1997 vehicles? barts Brakes & Brake Controllers 1 04-16-2012 03:48 PM
Shopping for a new brake controller...Suggestions? Chasmorgan Brakes & Brake Controllers 8 07-31-2011 10:45 AM
New F150 '09 brake controller vs. Prodigy brake controller dukester Brakes & Brake Controllers 17 01-20-2009 10:46 PM
