Old 05-14-2025, 12:33 PM   #1
2019 27' Globetrotter
East Hills , New York
Strange noise from bottom of trailer when trailer is stationary
Hi everyone.
I have a 2019 Globetrotter with 10K miles on it. When someone walks in the trailer a strange noise comes from the bottom of the trailer. It started toward the end of last season and has gotten worse this year. I went under the trailer while my wife walked around inside and it appears that it is coming from the center of the trailer near the tires and the holding tanks. But I could not isolate exactly where it is coming from. The forum wouldn't allow me to attach an audio or video file so I gave a link to the audio file below.
Appreciate if you could listen to it and provide some suggestions.
https://drive.google.com/file/d/1tLW...usp=drive_link
milesinmyles is offline   Reply With Quote
Old 05-14-2025, 12:53 PM   #2
OrangeCrush's Avatar
2017 25' Flying Cloud
Longmont , Colorado
Probably your brakes. We had/have similar noise on one side of the trailer. The dealer inspected them and said the brakes were fine and properly adjusted but the noise was coming from the pads slightly rubbing agains the drum. The noise is only noticeable when walking in the trailer without X chalks on the wheels due to the slight back and forth motion of the drum. If you have some X chalks try putting them on and see if the noise goes away.
OrangeCrush is offline   Reply With Quote
Old 05-14-2025, 01:00 PM   #3
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Following!
2018 27' FBT Globetrotter
2019 RAM Limited 2500 w/6.7 diesel
BRN 22721
Old 05-14-2025, 01:03 PM   #4
2014 27' FB International
Lewisville , Texas
Old Thread About This
The noise is the brake shoes rubbing against the backing plate. A small dab of grease is intended to lube this area. The grease has dried out or was never there in the first place.
A very extensive discussion on this may be read here.
https://www.airforums.com/forums/f36...ak-195598.html
Post #30 is where I fixed mine.
It is annoying but nothing to be concerned about. Unfortunately, the wheels and drums have to be removed to lube the effected area.
NO NOIZE is offline   Reply With Quote
Old 05-14-2025, 01:39 PM   #5
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
We had a sound much like that and it was a missing nut on one of the shocks. We acually had 2 nuts missing... It would be a good idea to check for loose or missing nuts on the shocks.
Richard
Old 05-14-2025, 03:27 PM   #6
LAWBC's Avatar
2013 27' FB International
2012 23' Flying Cloud
GVA , British Columbia
Wonder if it is in the rubber casing of the axel?
See breakdown of Dexter torsion axle, or the bracket to frame bolts.
ID:	453241   Click image for larger version
Laurence
LAWBC is offline   Reply With Quote
Old 05-14-2025, 07:00 PM   #7
2014 25' International
Vancouver Island , British Columbia
Squeeking noise while parked.
I have had that issue on and off for years. Brake inspection showed no issues.
Solution was to place wheel chock in front of right side rear wheel, slightly drive forward, place second chock behind front right wheel and shift TV into neutral to even out the preload on the two chocks effectively stabilizing the trailer preventing forward / rearward movement. This not only helps keep the trailer from moving but eliminates the noise, mystery solved. Hope this works for you.
DelBocaVista is offline   Reply With Quote
Old 05-15-2025, 08:10 AM   #8
Longmont , Colorado
You might give these a try. They are simple to use and eliminate the noise for us as well. Really good deal on them at Amazon right now.
https://www.amazon.com/X-Chock-Wheel...35178098&psc=1
Old 05-15-2025, 09:13 AM   #9
bigfoot390's Avatar
1999 30' Excella 1000
Chatham , Virginia
https://drive.google.com/file/d/1tLW...usp=drive_link[/QUOTE]
Turn up the stereo.
bigfoot390 is offline   Reply With Quote
Old 05-16-2025, 07:32 AM   #10
Longmont , Colorado
Turn up the stereo.[/QUOTE]
That sounds exactly like ours.
Old 05-21-2025, 09:47 AM   #11
2021 25' International
Show Low , Arizona
When the trailer is a squeaking don’t go a peaking!
We had this noise on our previous trailer and I’ve heard it on our Airstream as well. It’s the breaks/wheels. Nothing causing harm but can be annoying if you’re not chocked up well.
TechnoRoamer is offline   Reply With Quote
Old 05-21-2025, 09:55 AM   #12
2020 27' Flying Cloud
Chino , California
I have a 2020 Flying Cloud with the exact same noise! I have crawled under the trailer with my wife walking in the trailer and have not been able to identify the exact spot its coming from, but seems to be coming from the suspension. I have oiled and greased all the visible joints and bolts and nothing seems to work. Luckily we don't hear it when we are inside the trailer but it bothers me that something down there seems to need lube. I will try the posted suggestions and see if anything works.
Mikechrisman is offline   Reply With Quote
Old 05-21-2025, 01:46 PM   #13
2018 27' Flying Cloud
Carson CIty , NEVADA
Originally Posted by milesinmyles View Post
Hi everyone.
We're curious to a resolution here. We have a 2018 27' Flying Cloud FB and when parked, wheels choked and stabilizers down we hear a cha-chunk when entering and exiting the the coach. It it's brakes...
DannyT is offline   Reply With Quote
Old 05-21-2025, 09:16 PM   #14
2022 27' Globetrotter
Huntington Beach , California
Not sure what Danny T’s noise is but the OP’s noise is brakes/axel and X-chocked should solve it.
Slvr_Lining is offline   Reply With Quote
Old 05-22-2025, 09:11 AM   #15
TrvlTin
2023 30' Globetrotter
Boulder , Colorado
My Money is on the magnet:-)
My argument for the magnet and drum.
Magnet And spring
When I do brake inspection the drum when rotation makes minor sound with contact with brake shoes. When you give it a turn up wheel off. Good thing.
The magnet rides all the time up against drum. The spring in there middle of the magnet can lose some of its flexibility as brake dust and such. Also the magnet and spring gets very hot when electricity is applied. Electrons what are you gonna do?
I will turn or replace 2 of my drums in next 10.000 mi because there are not flat anymore. Th way the magnet is riding is making edges. It could also be torsion arm where it’s plugged in to the rubber cords on the hollow tube. Axle. Maybe the rubber cord making some noise? Either end of the shock maybe but still my money is on the magnet.
ID:	453430   Click image for larger version
TrvlngTinTin is offline   Reply With Quote
Old 05-22-2025, 09:36 AM   #16
LEV ZEPPELIN
crazylev's Avatar
Chicago , Illinois
One thing that has not been mentioned: squeaky stabilizers. When we had our AS, I would notice sound coming from underneath the trailer, so I lubed the stabilizer arms and that helped. Also the awning makes a racket too that would send sound through the interior. FWIW. Jonathan
crazylev is offline   Reply With Quote
Old 05-22-2025, 12:58 PM   #17
Mollysdad's Avatar
All pets accounted for?
Old 05-22-2025, 01:28 PM   #18
"Cloudsplitter"
My money is on the *KVO spring needing an adjustment.
Something in the suspension is rubbing something that doesn't like it, I reckon.
(*Kanuten Valve Opinion Spring.)
Kidding aside...Me being me, I'd have SWMBO hose a small section of the suspect area at a time while I bounce up and down inside, she then hollers like the Hatfields if/when the squeak stops.
Now, it might not be fixable, but at least it goes away when wet.
Strange noise?? Univolt?? Brakes?? rroessler General Repair Forum 4 08-07-2020 10:13 AM
strange noise rbs Brakes & Brake Controllers 16 07-09-2012 07:36 AM
Strange noise-Solar? clemdogmom Generators & Solar Power 5 11-04-2011 08:05 AM
1993 B190 with 460,strange noise! jhaun48 Sprinter and B-van Forum 5 10-28-2008 03:10 PM
Strange noise coming from the wheels wayne.yl Brakes & Brake Controllers 21 07-16-2008 03:38 PM
