Old 04-16-2021, 08:57 AM   #1
boger's Avatar
1969 31' Sovereign
Des Moines , Iowa
Recommended Install Location for Brake Actuator?
I am about to design a new frame for my 69' Sovereign shell off project. Will be going with disc brakes.
Looking for advice on the best location to install the disc brake actuator? I have zero hands-on experience with these, but I understand the concept mostly. I've searched the forums and can't seem to find this specific question. If I've missed it, please redirect me.
Better to install on exterior of trailer, near the tongue? Or inside the trailer? I see the units are vented (looked at Dexter for an example), so I don't want to add moisture or potential spills to the inside of the trailer. But, by putting on the outside of the trailer, that means I will likely have to run wires back through the shell to the actuator (or maybe I have to do that anyways for the breakaway switch). I had considered making space for a toolbox behind the propane tanks and putting the actuator in there, but that's just an idea.
Any help and advice is appreciated. Pictures are always helpful.
Jared
boger is offline   Reply With Quote
Old 04-16-2021, 09:01 AM   #2
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Jared
I would if possible avoid interior location. Brake fluid is nasty stuff. Mine is in what would have been the battery box in the A of the tongue.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook. BMV-712
GCinSC2 is offline   Reply With Quote
Dexter E/H Actuator to replace ActiBrake Actuator nickmeloy Brakes & Brake Controllers 32 10-22-2014 08:58 AM
Colonial Airstream Dexter Actuator Install craftsman Brakes & Brake Controllers 0 06-18-2010 11:23 AM
location location location goransons Airstreams on eBay 0 12-05-2009 09:29 AM
Location, Location, Location........... ROBERTSUNRUS Brakes & Brake Controllers 5 08-29-2009 06:13 PM
Stromburg Hydraulic Brake Actuator aprimosch Brakes & Brake Controllers 4 06-19-2007 01:32 PM
