08-01-2022, 10:42 PM
1978 31' Excella 500
Genoa
, Nevada
Need an electric/hydraulic disc brake actuator.
Does anyone know of a source for an electric over hydraulic disc brake actuator? Seems that all that I can find online are "out of stock". The Dexter model possibly available end of October.
Kind of need one in 3 weeks. Seems that the Actibrake that Andy sold me in 2007 doesn't want to work now. Only 15 years.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
08-02-2022, 02:57 AM
Etrailer is where we’d start our search. We’ve had great service from them.
William C. Swinney
08-02-2022, 10:20 PM
Genoa
, Nevada
Etrailer is out of stock.
NevadaGeo
08-02-2022, 10:43 PM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
You are looking for a pretty obscure item. Most likely way to get one quick is to call roughly a billion dealers and see if they have one on the shelf ....
08-03-2022, 04:59 AM
2007 30' Classic S/O
Somewhere
, South Carolina
Might be worth a call https://www.redneck-trailer.com/prod...ices/products/ from their website "Dexter has rebranded our Rockwell American and Redneck Trailer Supplies distribution branches to Dexter."
08-03-2022, 05:04 AM
They’re the McMaster-Carr of trailer stuff. If etrailer is out of stock then...
William C. Swinney
08-03-2022, 10:15 AM
2014 25' FB Eddie Bauer
Vero Beach
Tekonsha P3
If you’re looking for an external brake controller to plug into your F150 prewire (my tundra is prewired… I figure your F150 may be, too), the Tekonsha P3 is a widely used product, has elect over hydraulic support and is avail immediately from Amazon Prime.
I’m using the integrated controller in my current Tundra for electric only brakes, but used a P3 on my old Tundra and liked it better than the integrated unit I now have.
08-03-2022, 10:40 AM
Oswego
OP is looking for an actuator, not a controller.
-Rich-
08-03-2022, 01:00 PM
1960 24' Tradewind
dudley
, Massachusetts
Trailer Parts Superstore...Eastern Marine. Maybe they have something you can use
08-03-2022, 01:27 PM
2000 25' Safari
Davidson County
, NC Highlands County, FL
one available. sent you an email
Alan
08-03-2022, 02:57 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
Call Tustin, they make outstanding break controllers: DirectLink brake controllers.
I believe the make their own elec/hyd pump.
guskmg
08-04-2022, 12:13 AM
Genoa
, Nevada
The actuator is the thing on the trailer that your fancy controller tells to actuate and stomp on the hydraulic brake pedal and skid the tires. I've tested my controller on my Dodge diesel and it doesn't seem to be lack of signal issue, the Actibrake is sleeping and don't want to wake up. Pulling the old, and new brake away switch isn't doing it either.
NevadaGeo
08-04-2022, 12:16 AM
Genoa
, Nevada
Thanks, send it again please. I didn't find your email.
I'm finding a lot of surge actuators, but no electric over hydraulic disc brake actuators.
NevadaGeo
08-04-2022, 04:57 AM
Somewhere
, South Carolina
NevadaGeo,
How about going for a back to basics test on the Actibrake. Find the wiring and apply a temporary 12VDC jumper to it and see if it comes to life. Or try pulling the breakaway switch plug for a test.
Wiring diagram for the HBA series, but best to check your files for doc.
Gary
08-04-2022, 10:53 AM
1977 31' Excella 500
West Sacramento
Try Carlisle Brake and Friction and see if they still sell a 1600psi electric hydraulic actuator. Andy installed this in my trailer in 2011. Actibrake was recalled.
08-04-2022, 10:58 AM
Somewhere
, South Carolina
Originally Posted by GCinSC2
NevadaGeo,
Gary
OOPS my bad.
I DID have an Actibrake, it failed years ago and I replaced it with a Carlisle HBA-1600 actuator.
Should have caught my own early AM wrong word typo. The wiring diagram I posted is from my HBA-1600.
08-04-2022, 11:18 AM
West Sacramento
My Carlisle HBA 1600 has been trouble free. Hopefully Carlisle still makes the actuator.
08-05-2022, 12:45 AM
Genoa
, Nevada
OOPS my bad.
I did, and put on a new brake away switch, pulled it and it didn’t run the Actibrake. That’s when I decided I better look for a new actuator. I was confused why there was voltage on the thing until I read the instructions, again. The Actibrake has voltage on it all the time. The signal from the controller or breakaway switch tells the Actibrake to push on the hydraulic. Something blew the fuse at the Actibrake. I’ll try hot wiring it directly to a battery.
Carlisle doesn’t list a hydraulic brake actuator. .
08-05-2022, 06:20 AM
Oswego
I didn't see one on the Tucson site either??????
-Rich-
08-07-2022, 11:08 AM
LAKE MILLS
, Wisconsin
The reason you can't find one is a little more than a supply chain problem. I don't know the exact details, but the hydraulic brake actuator vendors can no longer buy the pumps they use in their products. Not only that but the pump they did temporarily have access to did not meet the specs of the pump it apparently replaced. I don't know if, or when, this situation will change. In effect a single source supplier problem whom "I think" seems unwilling or unable to provide functional hydraulic pumps. If the failure is NOT the pump itself, perhaps the "other parts" may be available but don't know of anyone who will cost effectively repair them. You might want to contact the respective manufacturer to see if they are willing to "repair" your failed unit.
