Old 05-13-2025, 07:32 AM   #1
KettleKayaker
2019 27' International
Glenbeulah , Wisconsin
inspecting my brakes on my 2019 27ft FB
Hi All,
Planning on inspecting my brakes on my 2019 27ft FB. I have 20,000 miles on the trailer. I have no brakes issues at this time. This will be my first inspection.
I have 4 new brake backing plates in case I would need them. I am a recent retiree and a "most timer" traveling about 15,000 miles per year in the last year.
If the shoes, drums and other hardware shows no sign of excessive wear or damage should I just clean things up with brake cleaner and not replace the backing plates? Is there a much greater chance of multiple things starting to go wrong with the brakes after 6 years and more than 25,000 miles. I would gladly take your suggestions!
2022 F-250 Lariat SuperCab
2019 International "Sweet Serenity" 27 ft FB
KettleKayaker is offline   Reply With Quote
Old 05-13-2025, 08:29 AM   #2
SafariSS's Avatar
2005 30' Safari
Houston Texas , Texas
Brakes
I have a 2005 Safari 30 Bunk that I bought new. Every May I pull off the drums and look at the brakes and grease bearings/replace seals. This year marks my 20th time doing it on this trailer and every year it amazes me how much a beating the grease takes. Glad I do not push these intervals. I travel alot in the hot summer and these bearings are something I would not want to have to deal with out on the road.
My opinion is just clean and adjust the brakes if they have plenty of pad. I am on my third backer plates with brakes in 127k miles of towing so they do last. My second set took a beating as I was doing a decent amount of boondocking with alot of weight (water etc) and towing with a lighter tow vehicle. This is the most important maintenance item on the Airstream if feel.
SafariSS is online now   Reply With Quote
Old 05-13-2025, 11:03 AM   #3
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Originally Posted by TrvlngTinTin View Post
Not my Wheelhouse?
But I thought I’d try a set of E Trailer Brakes.
Much much cheaper and look the same to me?
Bad idea???
They are usually cheaper for a reason - most likely made of "chinesium" and inferior components.....
2009 Dodge 2500, 6 Speed Auto, CTD, Quad Cab, Short Bed, ARE cap, Bed Rug
Propride 3P Hitch
WBCCI # 3072 Airstreaming since 2008
crispyboy is offline   Reply With Quote
Old 05-13-2025, 11:45 AM   #4
2019 25' Flying Cloud
Houston , Texas
We just had a shop inspect the brakes on our 2019 25FC with 39K on it. Report was 80% shoe material remaining. I would think you would be unlikely to need replacement. Look at the Dexter service material, there are one or two places which should be lubricated.
DCPAS is offline   Reply With Quote
Walking on the roof - cleaning / inspecting Resorts Roof 27 03-13-2021 07:21 PM
Inspecting '71 Overlander.. Axles and more streamahead Axles 12 09-16-2010 01:51 PM
BRAKES, BRAKES and more BRAKES Inland RV Center, In Commercial Listings 7 11-17-2009 05:56 PM
inspecting an old Airstream jerrypeterma General Repair Forum 6 07-25-2008 06:43 PM
