Old 03-26-2017, 11:27 PM   #1
1962 19' Globetrotter
canmore , Alberta
Send a message via Skype™ to hottrotter
Hydraulic brakes?
im going to pick up a 62 ' globetrotter 19ft, the guy who wont be there when i pick it up,says it has hydrolic brakes?? what do i need to hook to my truck? i dont have brake controller. he said im worring to much!!! can i just pull my trailer home with 7 way plug...4way? my truck is a chevy,4.7? mechanic is putting 7way 4 flat on?
hottrotter is offline   Reply With Quote
Old 03-28-2017, 10:08 AM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Hydraullic brakes were operated by vacuum. The system was not that reliable so Airstream discontinued that system. In addition parts are hard to find because many users just pitched the parts and switched to electric brakes.
Not having a brake controller and the 4 flat means you don't have the means to operate the brakes because you need the 7 pin connector and a brake controller to get brake operation. (If the system worked)
To tow a 19' foot that does not weight much you may be OK with brake operation. However you are taking a risk that may be illegal in some states.
With the 4 flat you may not have means to operate any lights because the trailer will have a round 7 pin connector. This is a condition that can get you stopped by the police as it IS illegal!
At minimum you need to find a way to get stop and turn signal lights. Brakes would be nice and with the small trailer I would take the risk IF you have a full sized tow vehicle.
>>>>>>>>>>>Action
Vacuum source for hydraulic brakes Coastalview Brakes & Brake Controllers 9 07-12-2014 08:41 AM
BRAKES, BRAKES and more BRAKES Inland RV Center, In Commercial Listings 7 11-17-2009 06:56 PM
57 trailer with hydraulic brakes Mariner Brakes & Brake Controllers 7 10-29-2003 12:34 AM
Hydraulic versus electric brakes jalewis Our Community 5 07-30-2003 09:49 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
