Old 01-21-2023, 05:48 PM   #1
1978 31' Sovereign
Richmond hill , Georgia
How does the emergency break away brake system work?
Hello all. I am in the process of restoring a 1978 sovereign from the ground up. It was a mess when I got it with most of the original wiring gone.
I am curious as to how the emergency break away brakes work on airstream rigs. Do the brakes directly receive a constant power supply from the 7-way plug that engages the brake when the electrical signal is interrupted? Or rather, is there some control unit in the trailer that takes care of this?
Thanks for your time!
-Brandon.
Brandon2022 is offline   Reply With Quote
Old 01-21-2023, 05:55 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
When the trailer separates from the tow vehicle the break away cable pulls the pin from the switch mounted on the trailer. The switch applies 12 volts from the trailer battery to the brake circuit which should cause all the wheels to lock up.
Richard
Old 01-21-2023, 06:01 PM   #3
2023 28' International
Mercer County , New Jersey
There is a separate cable that is attached to the vehicle. When the cable is pulled from the receptacle by the cable that is still attached to the TV (don't attach the cable to the hitch/receiver in the event that that also detaches from the TV), the circuit is completed and the electric brakes are activated with energy from the batteries. This is why it is required to have at least some sort of battery installed when towing an AS.
jeffb831 is offline   Reply With Quote
Old 01-21-2023, 08:56 PM   #4
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
There are two parallel power feeds going to the trailer brakes in an Airstream. The primary circuit begins in the tow vehicle and is controlled by the brake controller there. It sends power to the brakes via the 7-wire cable.
The breakaway emergency system typically feeds the brakes in the trailer by joining with the line coming from the tow vehicle just after where the 7-wire harness wire connects. The purpose of the breakaway power feed is to bypass the circuit originating from the tow vehicle, since when it's needed the tow vehicle won't be there any longer. This breakaway power feed is energized by the battery bank in the trailer.
There is a small switch mounted on the tongue of the trailer with a cable sticking out of one end. When this cable is pulled it completes the 12v+ circuit between the trailer battery and the trailer brake circuit, sending a full 12v+ to the brakes.
Richard
11018
richard5933 is offline   Reply With Quote
Old 01-22-2023, 04:37 AM   #5
1978 31' Sovereign
Ah ok. That makes sense. Is this feature an airstream specific feature? Or could I find aftermarket components readily?
(I’m ok with having non OEM parts if they are cheaper!)
Old 01-22-2023, 04:54 AM   #6
Chelsea , Maine
Airstream uses the same system every other trailer with electric brakes uses. It’s universal.
The plastic plunger in the switch keeps the contacts separated, keeping the switch open. When the plunger pulls out due to the trailer becoming detached the contacts come together and close the circuit, supplying 12v to the brakes.
Keep in mind, this is NOT a parking brake. The brakes will draw about 13 amps constantly and quickly drain the battery.
2017 FC 27FB
2017 F250 Lariat Crew Cab 6.2L
Equal-I-Zer 10K/1000
JMynes is offline   Reply With Quote
Old 01-22-2023, 07:27 AM   #7
2022 27' Globetrotter
DALLAS , TX
And continuous application of the maximum braking current can permanently damage the electric brakes on the trailer.
Just to add emphasis to the statement that the emergency brake is not a parking brake for the trailer.
foobar is offline   Reply With Quote
Old 01-22-2023, 07:33 AM   #8
Dennis C's Avatar
Evergreen , Colorado
There are stories of hitch failures occurring that cause the trailer to separate from the tow vehicle. They’re rare, but it can happen. I’ve read some of these stories here on these forums. If your emergency breakaway cable is attached to your hitch, then it may not activate the trailer brakes if you have a hitch failure. Many people attach their breakaway to their tow vehicle in another location to avoid this situation. I installed an eye bolt in one of my license plate mounting holes for the breakaway cable.
Dennis
Dennis C is offline   Reply With Quote
Old 01-22-2023, 08:33 AM   #9
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
X2 - brad
Looking for adventure in whatever comes our way.
- Brad
SuperTrouper is offline   Reply With Quote
Old 01-22-2023, 01:43 PM   #10
2018 30' Classic
2004 30' Classic
1972 Argosy 22
Meridian , Idaho
While they should be available at virtually any RV outlet here are some examples from Amazon.
https://www.amazon.com/trailer-break...eakaway+switch
cbburke is offline   Reply With Quote
Old 01-23-2023, 05:49 AM   #11
1978 31' Sovereign
Thank you all. The breakaway system makes more sense now. I’ll be ordering and installing one soon and will check back if I run into any problems.
Old 01-30-2023, 07:13 PM   #12
bambi-Lily
2016 19' International
encinitas , California
Yep. We can attest to this. We accidentally pulled the cable pin out and didn’t discover it for 24 hours. It basically killed our batteries (hit 10). Our solar got the batteries back up a bit and we were able to use a few things. Will need to replace them (batteries) this week
pegjust is offline   Reply With Quote
Old 01-30-2023, 11:05 PM   #13
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
Another point - the manual for my Tekonsha Prodigy P3 said that puling the breakaway cable with the umbilical connected to the truck can damage some brake controllers. Do any testing of the system with the 7-way cable disconnected.
Old 01-31-2023, 02:50 AM   #14
Boxite's Avatar
2008 22' Safari
And another point regarding the break-away cable: Do NOT leave Excess Length when attaching the cable….and AVOID those “coiled” types …which are designed to make it easy to attach but allows excess slack to exist in the event of trailer dis-connect from the ball.
Here’s why:
If your trailer comes Off the Ball…. it will hopefully fall onto your crossed-safety-chains. When that happens…the break-away cable should be sufficiently taut to activate your trailer brakes …Immediately… Otherwise the safety-chains will allow so much movement left-right of the trailer-tongue…that a Serious SWAY condition will likely occur…. one that can ROLL your tow vehicle. And unless you are quick-enough to think to manually apply your trailer brakes…(and that’s not likely,…what’s likely is you’ll let up on the accelerator and instantly CREATE a dangerous Sway….)
HOwever, if your break-away cable was properly adjusted it will have applied trailer-brakes…which will immediately pull-TAUT those safety-chains forcing the trailer to closely-follow the two vehicle. It will also instantly notify you of the problem via the decelerating effect the trailer will have on the vehicle.
Old 01-31-2023, 05:12 AM   #15
Silvr_Bullet's Avatar
2017 16' Sport
N/A , N/A
Researching some of the coiled Brake Cables and the older design, they are both 48” long. So I would question the theory as to which would separate first as they are the same length.
Silvr_Bullet is offline   Reply With Quote
Old 01-31-2023, 06:21 AM   #16
Boxite's Avatar
2008 22' Safari
The breakaway cable should be adjusted so as to remove excess length. This can be done either by routing it thru the attachment(s) on the vehicle and then back to the trailer…or by mechanically shortening it. I prefer to route it thru the trailer-hitch safety-chain loops….then thru a portion of my vehicle frame…then back to a carabiner kept on the safety-chain storage-loop on the trailer frame.
This allows me to make tight turns when trailering without activating the emerg-brakes… but will immediately activate the trailer brakes should the trailer become disconnected to the ball.
Old 01-31-2023, 06:29 AM   #17
2017 16' Sport
N/A , N/A
The coiled Breakaway Cable can be used in the same manner, if desired. Less chance of a snagged then broken or separating cable with coiled type, my opinion from personal experience with a broken old design cable.
Old 01-31-2023, 06:52 AM   #18
Boxite's Avatar
2008 22' Safari
I disagree that an aftermarket plastic, coiled cable is more durable than a genuine metal cable such as is Original Equipment.
If your cable should become snagged for any reason (such has improper routing) then it will apply the brakes…and you will therefore notice and correct the matter…. as long as the plastic type doesn’t snap rather than do its’ job of pulling the switch.
It’s your trailer so you can do as you wish, but it’s fairly well-known that the coiled plastic cables are intended for “ease of use” rather than durability.
Do you still have your Piper? Would you trust plastic flight control cables?
Old 01-31-2023, 07:44 AM   #19
2017 16' Sport
N/A , N/A
Just to be clear, it’s a cable with a plastic coat on it. It’s less likely to snag as it’s coil will provide some give. The reason the non coiled is provided is because they are less expensive.
Old 01-31-2023, 08:32 AM   #20
1994 25' Excella
Here’s why:
I fully understand your point here and agree with your theory that the breakaway system should engage as soon as the trailer drops off the ball.
But, this is a controversial topic with valid points to be made on both sides. There is a recent thread where this was discussed ad neuseam so it's probably not necessary to rehash that all. My point is to just mention that there are two seemingly valid viewpoints on this with different manufacturer's of equipment and trailers taking opposing sides here.
Richard
11018
Broken cable for the brake/break away KiraR Hitches, Couplers & Balls 14 06-29-2015 07:26 AM
Hook Emergency Break-away cable to what? OB Bambi Brakes & Brake Controllers 16 08-18-2011 03:35 PM
Break away brake cable Cap-N-Red On The Road... 26 04-10-2011 03:10 PM
Break away brake cable glogeo Hitches, Couplers & Balls 2 09-23-2010 03:57 PM
Break Away Brake Switch davespann Brakes & Brake Controllers 1 07-30-2003 08:22 PM
