Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Brakes & Brake Controllers
Old 05-24-2009, 08:22 PM   #1
1962 28' Ambassador
Gravois Mills , Missouri
HELP! 07 Dodge Dakota brake control wiring.
I have a 2007 Dodge Dakota 4x4 SLT extended cab truck. I installed a Tankosha controller, wired the plug kit to it, and plugged it in to the trailer brake port under the dash. However, when I got under the truck and looked at the wires inside the harness tube at the back of the truck, I could'nt find anything that matched the wires coming out of the back of the port nd going through the firewall. Where do I find a connection point? is there a block or terminated ends inside the harness protective tubing nearer the firewall?
The 7 point plug I installed on the truck is of the type that has a 4 pin flat adaptor and blk/blu/yel loose wires with a white ground loop.
SANTINO MARC is offline   Reply With Quote
Dodge Dakota - TV? jmichaelr Tow Vehicles 7 07-08-2008 08:07 PM
dodge dakota towing 27' airmac Tow Vehicles 25 12-17-2007 07:25 PM
Dodge Dakota + Safari 23' Widgeon Tow Vehicles 6 11-20-2005 02:50 PM
Dodge Dakota Sport Towing Mirrors (2002 model) Paul and Sue Tow Vehicles 1 05-15-2003 10:25 AM
