Originally Posted by LivingInBeauty
We do have a new switch, bought May 2024.
I checked the connections as far as I can, but the wires go into the frame within 10 inches of the switch, so I can't follow where they go.
When I pull out the pin and walk to the brakes, I hear nothing, but when we are driving and I pinch the brake levers on the trucks dashboard, we can feel the brakes engaging.
Not sure my next step.
The wires go into the frame through a hole, and if you slide underneath the front of the chassis you'll likely find another hole where they come out before entering the trailer.
But, if you have 10 inches of wire then you have more than enough to replace the switch. Every one I've seen is replaced by clipping the old wires close to the old switch and then using butt connectors to join the wires on the new switch to the ends of the wires left after snipping off the old switch. Doesn't matter which wire is which when you reconnect - this is a simple on/off switch with no polarity.
In general, these switches are not weatherproof and after a few years build up enough dirt and corrosion to stop them from working. Also, the mechanism inside the switch is simply two pieces of metal bent so that they make contact, and the pin is in there to keep them apart till it is pulled out. The metal can fatigue over time which means they don't push together so firmly when the pin is pulled.
If you replace the switch and the e-brakes are still not functioning you'll have to dig deeper.
One important thing to remember is that you must have a charged battery for the e-brake to function. If the pin is pulled while you are driving, it's because the tow vehicle and the trailer have separated. There is no longer
12v power flowing from the tow vehicle and the e-brakes rely solely on the trailer's battery to engage.
If you're trying to test the e-brakes when you're not hitched up and have power to the 7-wire harness you must have a charged battery in the trailer with power flowing to the e-brake circuit.
If the battery is in place and charged, check to see if you have
12v power in one of the leads going to the switch. If not, then work backwards into the trailer to see where the break in the line is.
Originally Posted by tjdonahoe
Have to be moving to work
Still should be able to hear/feel the magnets moving.
