Old 07-25-2024, 09:22 AM   #1
2019 25' International
Atlanta , Georgia
Electric trailer brake question
I have a 2018 Expedition with full tow package and trailer with duel axles.
While parked in my driveway, I set the brake controller to 10 and had my wife push the brake pedal in while I measured DC amps at each brake. I was only reading 1.5 amps on each brake wire, instead of 3 amps. Batteries are 12.7v.
Does this mean my brakes are halfway worn? Thanks in advance.
1590Denny is offline   Reply With Quote
Old 07-25-2024, 09:33 AM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Not sure what that test means if it means anything. The trailer braking is proportional to the truck braking so the truck has to be moving and then an accelerometer send the brake signal to the trailer based on how hard the truck is being stopped. There is a second kind of braking that activates when the brake lights come on. That sends a partial signal to lightly activate the trailer brads. I expect that is what you are metering. I do not know a way to meter how much braking is happening during motion unless you brake controller reports that. At least this is the way the add on brake controllers work. I do not know for sure but suspect that built in controllers now operate in the same manner. I do not think they operate from a measure of the hydraulic pressure in the truck brakes any more.
Old 07-25-2024, 09:51 AM   #3
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
you need to be moving as bill m states to test your brakes/controller
the best setting on our controller is 2.9
that was chosen after miles of driving to ensure the brakes engaged and did not lock up
each tv / trailer combination is unique
you just need to test and experiment
there is no default setting
2023 25' FB FC, hatch, Queen,30A,1AC,Awning pkg, Convection uwave.Multiplus 12/3000-50,700A Lion,MPPT 100/30,Orion-TR 30,Cerbo GX,GX touch 50,Lynx distributor,dual BMV-712, smart shunt 500A&1000A, RUUVI temp/humidity sensors,2 Mopeka LP sensors
NCR,Ontario,VE3HIU since 1978
WBCCI# 21212
waninae39 is offline   Reply With Quote
Old 07-25-2024, 10:04 AM   #4
DKB_SATX's Avatar
Alamo Heights , Texas
I think if you want to measure possible peak output from a proprotional brake controller you have to use the manual lever rather than pressing the brakes while stopped. I'd expect lower output when the controller doesn't detect any motion or deceleration.
— David
DKB_SATX is online now   Reply With Quote
Old 07-25-2024, 02:00 PM   #5
1988 25' Excella
1987 32' Excella
Yes, pull the lever, That should give you the maximum current the controller is set for.
Old 07-25-2024, 02:27 PM   #6
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Yes, what they said. Drive at 20 mph with the controller set to 10 and pull the lever to max. Did wheels lock up? If so, you're good.
Mine didn't do it and I found a broken splice to a brake magnet that was hidden under shrink tubing. I fixed that connection and another that seemed ready to go, and I passed the test with flying colors.
2019 Ford Expedition Platinum
Old 07-25-2024, 05:23 PM   #7
Atlanta , Georgia
Thank you all for responding.
Old 07-26-2024, 12:21 PM   #8
2012 23' FB International
Woodstock , Ontario
The controller reads volts not amps and will give same voltage whether worn or brand new
The magnets respond to varying voltage. The only way to check brake wear is remove the Drum's
JCWDCW is offline   Reply With Quote
Older Airstream hydraulic brake to electric brake conversion fastinjun71 Brakes & Brake Controllers 1 06-09-2016 02:46 PM
Electric Brake Question Gastrolith Brakes & Brake Controllers 4 06-21-2011 08:11 PM
Newby question, electric brake problem howco Brakes & Brake Controllers 5 06-11-2010 04:33 PM
Electric Brake Question 68 Suburban Brakes & Brake Controllers 6 03-04-2003 08:09 PM
Electric Brake Question. 68 Suburban Brakes & Brake Controllers 7 10-11-2002 09:14 AM
