02-06-2021, 07:32 AM
#21
Oswego
Originally Posted by STREMN
Hi Rich,
The Actuator was replaced with a: Dexter Model E/H 1600
For reference the recall inspection procedure: Attachment 388178
AirStream Customer Recall Notice Actuator: Attachment 388179
AirStream Customer Recall Notice Brake Lines: Attachment 388180
Tom - S/OS #025
Thanks, what has been your experience with the dexter actuator? Any apply lag time...etc.
-Rich-
02-06-2021, 09:57 AM
#22
2008 30' Classic S/O
Hampton Beach
, New Hampshire
EOH Safety Recall
Works awesome! The system is responsive, confident and strong. We're so spoiled by the disc performance.
"Lag" time is primarily a product of system setup. There's a long line from the actuator to the axles. Attention to details like ensuring the hydraulic lines are bled of all air bubbles let's the system work efficiently as designed.
Tom - S/OS #025
- Tom and Wendy - AirSTREMN from New Hampshire -
- 2008 30' Classic S/O - S/OS #025 - Riding on 16" Wheels and Tires -
- Live Free or Die -
02-06-2021, 10:27 AM
#23
Oswego
Tom - S/OS #025
Right, the problem with these actuators is that none that I know of utilize an accumulator, like automotive hydraulic boosters. Thus, there is no pressurized fluid at the ready and you have to wait for the pump to spool up pressure. That bamboozles me!
I have become an expert in bleeding the brakes after installing longer caliper hoses and exchanging fluid 2 additional times over the years.
-Rich-
02-06-2021, 11:09 AM
#24
2007 30' Classic S/O
Somewhere
, South Carolina
Rich
Puzzled by the comparison to automotive accumulator comment. Care to elaborate on the automotive here it is on a car or truck?
I’d rather be tending a nice campfire.
Gary
02-06-2021, 12:28 PM
#25
Oswego
Originally Posted by GCinSC2
Rich
Gary
Older gm hydroboost systems used a high pressure accumulator so power brakes always had assist available. I dont understand why trailer manufacturers dont use a similar setup so there is always high pressure fluid available for immediate brake line pressure upon pedal application.
It was used on a number of low vacuum engine combinations. Buick Grand National comes to mind.
-Rich-
02-06-2021, 01:56 PM
#26
Somewhere
, South Carolina
Hydroboost is common on diesel pick up trucks. My 2005 Dodge has one. It uses the PS pump systems pressure in place of engine vacuum and the vacuum booster to provide reduced pedal effort for the brakes. It also provides for an application or two of power assisted braking with the engine off via its accumulator just like a vacuum booster does.
It reduces the effort required by the driver to push the brake pedal down. It doesn't maintain hydraulic pressure in the brake system.
But it looks like the OP hasn't come back for a follow up or current status.
02-06-2021, 08:56 PM
#27
Oswego
Ugg, Gary. You're not getting my meaning. I said a system similar to hydroboost to provide ready pressurized brake fluid to be regulated by the controller. I am fully aware that hydroboost was for assist, and I stated that. While the accumulator was only about 200 psi on hydroboost, line pressure could always be boosted by a "master cylinder" piston of the proper diameter to provide 1600psi normally utilized for trailer disc brake systems.
Better yet, just design a more robust accumulator at the existing 1600psi and just modulate it with electronically and processor controlled flow valve.
And yes, diesels are one of the low vacuum powertrains I referenced.
-Rich-
02-06-2021, 09:02 PM
#28
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
I have mentioned this before about TT with Dexter A/H units. In cold weather they can draw higher amps than the old "Actibrake" units. The regular electrical brake power wiring has been changed to accommodate that increase. However, the emergency breakaway switch and wiring has not, and will only last 5 seconds or so then it will burn out. Airstream techs say that is why the Owners Manual says not to use it as a parking brake. The pump change was after the breakaway system was installed. Go figure!
guskmg
02-06-2021, 09:15 PM
#29
Oswego
guskmg
I was scanning the Tucson manual yesterday. They also mention larger wire size for install. Not sure they mention the breakaway switch. Does anyone produce a more robust breakaway switch?
-Rich-
02-11-2021, 03:19 PM
#30
LAKE MILLS
, Wisconsin
The Tuson unit pulls "very little current" from blue wire, and thus a break away switch connected to blue wire (if conventional wiring) would work fine. If a separate red wire is connected to break away input (not to blue wire) this input also pulls "very little current", is monitored by CPU which then activates brakes. So no problem with break away switch. Tuson unit pulls its power from the black wire (battery) and thus does not draw high motor currents from a break away switch. Thus, per someones comment, a full size trailer battery with larger wire from battery to actuator will reduce voltage drop at high inrush currents and come up to pressure faster. Additionally the Tuson unit has the pressure modulating valve wide open when starting where other units are modulating the valve and thus Tuson comes up to pressure faster. Hope this helps.
