Dexter Axles Disk Brakes
Im looking for the brake pads for my 2009 25FB Classic Limited. It has Dexter Nev-R-lube and in the Airstream Parts manual it only list the following axles 3800, 5000, 4400. For my 25FB it lists the 3800 Airstream Part# 410875. My question is the trailer is rated at 8000 GW. If airstream has installed only 3800 lb axles then the trailer is over the weight limit of the axles. 3800 x 2 = 7600 lb about 400 lbs light. I go to Dexter Webpage and find they list 3500 lb, SO question what axles do I have? Where can I find just brake pads?
Bob & Julie # 5587, 4CU in AZ
