01-27-2012, 12:33 PM
Corona
Carlisle Actuator Recall
RECALL ON CARLISLE ACTUATOR
We just received notice of a RECALL for the Carlisle disc brake actuators.
The following link provides the MODEL and SERIAL NUMBERS.
The link also provides instructions of what to do.
PLEASE CHECK YOUR CARLISLE ACTUATOR MODEL AND SERIAL NUMBER, NOW!!!!
01-27-2012, 01:20 PM
Corona
link
01-27-2012, 02:31 PM
Corona
link
Downloading somedays, is not my cup of tea.
This notice is for the Carlisle Hydrastar and Hydrastar XL actuators, made between August and December 2011.
The serial number for the Hydrastar 10, 12 and 16 are;
323896 thry 324093
515122 thru 517531
715739 thru 717001
The serial numbers for the Hydrastar XL 10, 12 and 16 are;
517532 thru 517533
602058 thru 602085
623888 thru 623894
Suspect units shouild be returned to Carlisle Brake and Friction. 1031 E. Hillside Drive, Bloomington. IN, 47401.
Replacement units will be provided.
CONTACT Customer service at 1-800-933-1001, for arrangements.
01-27-2012, 04:51 PM
1984 31' Airstream310
Ajo
Do AS dealers eat the labor and backbill?
01-27-2012, 05:56 PM
2007 30' Classic S/O
Somewhere
, South Carolina
Andy,
Thanks for posting. I checked mine and it's 513XXX. Looks like I dodged this recall.
For those of you that need to remove your actuator, you might want to cap the end of the line to prevent leaks and exposing the fluid in the line to atmosphere. I found this combination will correctly cap a 3/16" steel brake line, a 3/16" coupler and a 3/16" plug, please note: the 3/16" is the size of the brake line and the nut size is 3/8".
Good luck to all.
Gary
01-27-2012, 07:51 PM
Corona
Mike.
I have no idea.
You will have to check with Airstream.
937-596-6111
01-27-2012, 11:09 PM
1977 31' Excella 500
West Sacramento
I'm in the clear too as mine was manufactured in 2010. Andy, did Carlisle say to you exactly what is defective?
01-28-2012, 04:37 AM
Moderator dude
1966 26' Overlander
Phoenix
Doug, In the letter in he thumbnail it states the pump in the actuator is defective.
>>>>>Action
01-28-2012, 09:22 PM
1960 26' Overlander
1963 24' Tradewind
El Paso
Where can I get info on the ActiBrake recall?I included a picture of the only numbers I could find.
01-29-2012, 08:10 AM
Corona
Best we know, Actibrake is no longer in business.
01-29-2012, 08:28 AM
Somewhere
, South Carolina
desertair27,
Maybe I confused this on your other thread this http://www.airforums.com/forums/f439...ics-67620.html I believe covers ActiBrake units sold with an AS trailer, possibly not installed as a customer replacement. But you should read the PDF bulletin attached in the thread and I think a good do it yourself type could do the same if you chose to, just be very carefull where you drill for the inspection hole to look for fluid, don't make this mistake drilling http://www.airforums.com/forums/f439...iew-85382.html
Gary
01-29-2012, 09:31 AM
1960 26' Overlander
1963 24' Tradewind
El Paso
Originally Posted by GCinSC2
Awesome Gary, thanks
01-29-2012, 09:32 AM
1960 26' Overlander
1963 24' Tradewind
El Paso
Thanks Andy
01-29-2012, 12:40 PM
1960 33' Custom
Athens
After my 3 year old Actibrake crapped out after about 2500 miles use I had the Carlisle installed. Luckily my Serial # is outside the recall but I doubt I'll use this set up on the next trailer. I hate to say it but drums seem to work just fine and are easier to troubleshoot.
1960 Sovereign 33' Pacific Railroad Custom
