Old 10-01-2024, 12:56 PM   #1
2018 22' Sport
Salem , OR
Question brake wire at trailer wheel cut; how to test repair
While searching for mouse access points, I noticed that the white wire leading to the brake on the left side of my 2018 Bambi Sport was disconnected. My plan is to reconnect the wires with a twist connector. How do I test for proper function of both left and right brakes on the trailer? I have no idea how long this has been the case. Probably should check the brake status in general, correct?
Rob Gramenz is offline   Reply With Quote
Old 10-01-2024, 02:52 PM   #2
Ray Eklund's Avatar
2019 27' International
2014 25' International
Oregon Buttes , Wyoming
Rob.... I am the last person who should give electrical advice, 12 volt or 110 volt. I test 9 volt batteries with my tongue.
But... even a Neanderthal... has one way to TEST your Brake Wiring repair. Learned by experimenting and finding a broken wire on my 2006 non working brake, where the wire goes into the drum.
Get the wheel in the air, as if you are changing a flat tire. Have someone spin the wheel. Pull out the Break Away Switch. If the wheel locks up... quickly connect the Break Switch. Fixed and you are now experienced with this part.
While you are getting onto this. Do the same on the opposite side. Pull out the Break Away Switch... if this wheel locks, Reconnect the break away and celebrate.
Do not leave the Break Away Switch activated. Then... you will have serious problems. AKA? Brake Away Switch? Either name. Same Fix.
Human Bean
Ray Eklund is offline   Reply With Quote
Old 10-01-2024, 04:06 PM   #3
2022 25' Flying Cloud
Tualatin , Oregon
Rob,
Another option is to grab your trusty magnetic compass. Engage the Break Away Switch and when the compass is held close to your drum you'll see the needle swing toward the drum. Don't forget to replace the plug when done testing.
Steve
TitusNW is offline   Reply With Quote
Old 10-01-2024, 09:35 PM   #4
2018 22' Sport
Salem , OR
Originally Posted by TitusNW View Post
Rob,
Steve
I'll try it tomorrow. Thanks so much. To be honest, it was very hard to pull the breakaway pin out and I've not done it until now. I need such encouragement and great advice. Tomorrow, the battery will be connected! And I will try the wheel spin test as well; as you might guess, I have never lifted the trailer with my bottle jack so here's my opportunity to practice it.
Old 10-02-2024, 10:24 AM   #5
2018 27' Flying Cloud
Atlanta , Georgia
I strongly suggest you use Wago Lever nuts rather than wire nuts for the connection. The wire nut will eventually come loose. Also be sure the wire is far from the brake. I had to do this twice when the wire got caught in the brake while turning and broke the wire a second time. Use electrical tape to tape everything together.
I went a whole summer without one of the 4 brakes on my 28' with 2 axles. I couldn't figure out why the opposite tire on the axle was wearing quickly. Almost no tread left after the summer. If you want a gauge how long the wire has been disconnected, look for excess wear on the tire on the other side. It has been doing all the braking work.
jnm30327 is offline   Reply With Quote
Old 10-02-2024, 10:48 AM   #6
2012 23' FB International
Woodstock , Ontario
You can usually hear the brake magnet singing when brake is applied.The controller chops the DC into varying pulse lengths as it increases the voltage and you can hear the pulsing at the wheel.
As noted a compass works if you have one.
JCWDCW is offline   Reply With Quote
Old 10-02-2024, 10:51 AM   #7
2014 27' FB International
Hooper , Utah
Use a waterproof electrical crimping connector:
https://www.amazon.com/Haisstronica-...ail_img_1&th=1
Purchase a crimping tool or use plyers.
albret is offline   Reply With Quote
Old 10-02-2024, 02:28 PM   #8
Hermes's Avatar
2016 28' International
Trois-Rivieres , Quebec
Good recommendation for reconnecting the wires. Where the wire enters the hub, I would protect it with a rubber grommet or tape, since the rubbing will eventually cut it.
Agree with Ray, jack one side, pull out the pin on the break away switch, try to spin the two wheels. If the connection is good they won't spin.
My brake away cable got caught in the hitch once, it pulled out the pin, and I burned two brakes as I drove a bit too far, but one wheel was perfect, it had a cut wire. They are worth checking. The other thing about break away switch cables, get the red spiral one, it won't snag and pull the pin (it cost me $$$ to learn that lesson).
2016 International Signature CCD, RBQ, Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap
Lift kit, 16" wheels, Michelin Agilis CC LT
DIY Solar: 500W Renogy panels, AM Solar hdw, Blue Sky MPPT controller, 470ah Rolls battery bank, 2000W Renogy inverter.
Hermes is offline   Reply With Quote
Old 10-02-2024, 07:07 PM   #9
Steamy1's Avatar
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
I would only use a butt connector if the wire is cut outside on the backside of the brake backing plate.
In addition, I would suggest covering the butt connector with shrink tubing then the entire length of the paired wires with loom tubing conduit. Use zip ties to secure the wiring.
Make sure to include a small loop in the wires just before it enters the backing plate to absorb movement.
"Keep your eyes on the road
Your hand upon the wheel"
Steamy1 is offline   Reply With Quote
Old 10-06-2024, 10:44 AM   #10
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
At the end of last season I noticed my brakes were weak. If you don't do heavy braking, the auto adjusters don't always do their job.
So this spring I drove down a stretch of straight road and hit the manual brake control several times. That got the adjusters to work and braking was much better. I then checked the temperature of each wheel. Three were warm but one was at ambient temperature.
Checking the wiring to that wheel I found the factory butt splice came apart but you could see it because it was inside the shrink tube.
I repaired the splice with a Wago connector and wrapped the daylights out of it with tape.
Did another test drive and all wheels were the same temp.
2019 Ford Expedition Platinum
Old 10-07-2024, 12:18 AM   #11
2018 22' Sport
Salem , OR
Thanks for your advice and teaching for this willing learner. I tried a tiny little compass that came attached to my ultralight backpack shoulder strap. My wife was a bit distracted and said she couldn't tell if the needle moved much or not. Since I wanted to practice using the bottle jack anyway, I did that method. She was very clear that the wheel did indeed stop moving when I pulled the breakaway. This forum is such a fantastic resource; I need to monitor it regularly myself to pay it forward. I've learned a thing or 2 after 16,000 miles on the road.
wheel noise when brake wire broke dst General Repair Forum 2 06-12-2021 08:19 AM
Cut wire to brake magnet GreggH Brakes & Brake Controllers 1 09-27-2006 05:45 PM
Big 'Ol Cut Wire At Breaker Box squrlgurl Electrical - Systems, Generators, Batteries & Solar 16 11-12-2005 04:06 PM
Wire ,wire, oh wire can it be ? 69 Silverback Electrical - Systems, Generators, Batteries & Solar 8 05-15-2003 12:09 PM
