Old 07-11-2020, 07:11 AM   #1
2015 30' Flying Cloud
Port Sanilac , Michigan
Brake Pad Thickness
How do you know when you need to replace the brakes. After 30,000 miles I pulled off a brake drum to have a look at my auto adjust brakes. Magnet looks good and the shoes are about 3/32 inch thick. Can I keep going or is it time to replace?
pontzdav is offline   Reply With Quote
Old 07-11-2020, 07:18 AM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Replace...bonded shoes do NOT like to be thin.🥴
It's not so much how thick thick the friction material is, it's how well it's stuck to the 'shoe'.
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Worry...a brain exercise done when it really wants to sleep"
RLC
Tahawus
Old 07-11-2020, 08:06 AM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
You are almost ready for new shoes. I would go ahead and replace them now, before the drums get damaged.
copy/paste from Etrailer.com>
"Electric Brake Assembly # 23-458 the shoe pad thickness is 3/16 of an inch. Dexter says that you should replace the shoes if the material gets down to 1/16 of an inch thick or less."
Alan
Old 07-11-2020, 07:34 PM   #4
Thank you AW Warn. After I saw your post I visited etrailer.com and found the same info. Perfect. When I get home from the current 4000 mile trip Iím going to inspect all 4 brakes and measure the thickness. If Iím getting close to 1/16Ē I will replace. Thanks
Old 07-17-2020, 07:15 PM   #5
I pulled all 4 never lube hubs today. All four showed similar and very little wear for 40,000. I measured the shoe thickness at about 0.17 inches. Magnets and drums looked good. I’m pleased with what is less than half worn. I’ll have another look in 2022. Not too big of a job. Needed to use a 2 ft. breaker bar to get the big nut off.
Old 07-17-2020, 07:20 PM   #6
Pics
Pics
ID:	373159   Click image for larger version
F-150 Brake Pad Upgrade Wconley Tow Vehicles 8 04-01-2018 06:43 AM
Where are the Specs for Brake Drum Thickness? Maitland Brakes & Brake Controllers 8 08-28-2016 06:13 AM
Lost One Brake Pad Buttercup Brakes & Brake Controllers 34 07-23-2012 08:44 AM
Disc Brake Pad Disintegrates On '06 DEITZ645 Brakes & Brake Controllers 20 07-29-2009 07:19 PM
