Old 10-22-2016, 12:28 PM   #1
2012 23' Flying Cloud
2014 25' FB International
2014 27' FB International
Sugar Valley , Georgia
brake magnets
Another question please. Does anyone know how thick the magnets are when new? Mine measure @.720 inches. If they were .750 when new, I won't worry. If they were 1.00 when new, might be time to worry. Thanks for your time. Mike
Mike S. is offline   Reply With Quote
Old 10-22-2016, 12:33 PM   #2
Retired.
. , At Large
It depends on which magnets, what size brakes, how old the magnets are.
Old 10-22-2016, 12:56 PM   #3
Axles were made in sept 2013, 12 x 2 brakes. Axles are 3800# capacity.
Thanks, Mike
Old 10-22-2016, 01:36 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
Generally there small holes on the face of the magnet. When any area of those holes disappear, they don't always ware evenly, it is time to replace. If left beyond that point you run the risk of cutting into the coil windings.
2004 Excursion 4x4
Old 04-04-2017, 11:54 AM   #5
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
Just did magnet replaced this weekend as well.. did not measure the new ones but I can drop by the place we get them Agri Supply and measure the thickness..
I will post some pic of the ones I took out.
you can see coils on a couple of them. Was an all day deal but it gave me chance to repack bearings, check hubs and smooth out the magnet side of hub, and rotate tires back to front.
Two picture show old units and ones shows a new one.
PS tried to call tractor supply and spoke with one of the girls and she was not able to find replacement magnets there and could not find them on the website either.
ID:	282680   Click image for larger version
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D 460 watts solar, lithium 230 AH, 16" LT's, pulled by:
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 04-04-2017, 12:06 PM   #6
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
Place a straightedge ruler edge on the magnet in several orientations (lengthwise, crosswise, diagonally, etc. If there are gaps, i.e. unevenly worn edges like yours, they should be replaced. If wires showing, definitely should be replaced.
If one magnet on an axle is changed, the other should be, as well.
Also, check the magnet surface on the flat inside of the drum. If badly scored, the drum should be turned or replaced. Not many places can turn brake drums anymore. The best bet is a truck repair shop. Most can turn the round shoe surface, only a few can turn the flat side. If one drum on an axle is turned/changed, the other drum should be as well.
http://www.dexteraxle.com/docs/defau...s.pdf?sfvrsn=2
Al
Al, K5TAN and Missy, N4RGO - WBCCI 1322
2013 Ram 2500 Laramie 4x4 Megacab Cummins
Old 04-05-2017, 06:56 AM   #7
carl2591's Avatar
2005 31' Classic
Yeah did that .. change all the magnets all of which showed different types of year but all were past the holes in the maganets.
The drums inner surface was not bad, some had a bit of scoring so I took emery cloth and sanded to smooth and rough up the surface.
Yesterday I was able to take the trailer on a drive,over to Discount tire to get a complete 4 wheel balance, and along the way was engaging the trailer brakes to burnish and break in the new magnets.
Since I was in a bit of traffice and not able to do the 40 mph to 20 mph deal I wouild get in "clean air" accelerate and pull the trailer brake handle holding it on for 5 to 6 seconds while mashing the gas and release and let it cool for a min or so and do again.. I was able to do this about 4 times on the way there and got tires balanced.
coming back I noticed the brakes now were 1000% better to where i had to back down brake gain to keep from snatching the truck with trailer brakes.
MAN what a difference for sure.. this all started due to a hot hub after we went to pickup unit at storage area. All is good now.
Carl, Raleigh NC
Old 04-07-2017, 08:48 PM   #8
carl2591's Avatar
2005 31' Classic
size of magnet: 3.16" x 2.02" W x 0.95" D
this is from a website that sell magnets for a lot of money.. Agri Supply price is 6.99 each.. most places are like 12 or more each plus shipping.
Carl, Raleigh NC
Testing brake magnets goshawks00 Brakes & Brake Controllers 2 11-21-2011 07:48 AM
Brake magnets kingfisher24 Brakes & Brake Controllers 11 05-18-2011 10:22 AM
Brake magnets 1976 Sovereign Splitrock Brakes & Brake Controllers 2 07-31-2010 01:29 PM
Grease on brake magnets lbrodsky Brakes & Brake Controllers 43 11-25-2006 07:06 PM
Need a couple of old brake magnets Excella CM Brakes & Brake Controllers 1 07-02-2006 07:47 AM
