Old 02-07-2020, 01:18 PM   #1
Atlas CA's Avatar
2012 16' International
Alameda , CA
Brake Controller
Hey folks! New member here. My wife and I are towing noobs and just purchased a 2012 16' International Serenity. Our tow vehicle is a 2012 VW Touareg V6. I've been looking into brake controllers but there are many options out there - ranging from $40-$350. Any advice on which would work best with this combination? I'd hate to get something cheap that doesn't work properly but don't want to spend too much on something that's only for a 16' trailer.
Atlas CA is offline   Reply With Quote
Old 02-07-2020, 03:36 PM   #2
waninae39's Avatar
2017 22' Sport
NCR , Ontario
Tekonsha P3 Electronic controller
fully adjustable
best to go a a reputable trailer dealer and have them set it and up and show you how they do it. we used CANAM in london ON
the trick is to adjust it so that the trailer brakes just start to lock, then dial it down a notch so they don't. nit enough control, then the brakes on the trailer or of little use. too much and the trailer will brake lock too easily
after the initial dealer setup, you may need to adjust the P3 controller if the trailer load changes much since the initial setup. usually there is no need
waninae39 is offline   Reply With Quote
Old 02-07-2020, 04:16 PM   #3
Halford1's Avatar
2019 19' Flying Cloud
Canyon Country , California
I have Tekonsha wireless brake controller. I can use it on ANY vehicle with Tow Package if these did not have wiring for Brake Controller. Easy to use.
2014 Ford Explorer XLT with factory installed Tow Package.
2019 Flying Cloud 19CBB
Halford1 is offline   Reply With Quote
Old 02-07-2020, 05:17 PM   #4
2018 27' Globetrotter
Elbert , CO
We also went with the Tekonsha P3 on our NV. It interfaced with the factory wiring very easily - total install time was about 1/2 hour.
djb75 is offline   Reply With Quote
Old 02-07-2020, 05:57 PM   #5
2019 22' Sport
Carlsbad , California
Curt Echo. Easier than any other option, and no install required. Also not as expensive as many options. Its been working great for me for over a year.
Prettygood is offline   Reply With Quote
Old 02-07-2020, 05:59 PM   #6
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Check the eTrailer Touareg installation video
Hi Atlas CA,
Congratulations and welcome to the Airstream community and forums!
We had a 2016 VW Touareg TDI and a FC23FB. I bought a Tekonsha Prodigy P2 from eTrailer after finding their installation video on a Touareg.
I'm guessing yours would have the VW factory brake controller connector tucked under the dash. eTrailer shows you how to make a pigtail using the VW parts connector and wires at the 5:20 mark. This makes it simple to connect the Prodigy.
Here's the eTrailer page: https://www.etrailer.com/tv-install-...reg-90885.aspx
By the way, the connector under the dash was wrapped in white foam. I did have to drop the lower plastic panel and lay on my back to get to the plug.
The controller worked great; just make sure you set the gain by testing on a quiet road of parking lot before heading out. You should feel the trailer brakes engage when you manually engage the lever on the controller.
Good luck!
Jeff
Name:	Screen Shot 2020-02-07 at 6.58.09 PM.png
2019 27 Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 02-09-2020, 10:47 AM   #7
Atlas CA's Avatar
Alameda , CA
Excellent, thank you all for the quick responses!
Old 02-10-2020, 06:52 PM   #8
travco72's Avatar
Toronto , Ontario
Brake Controller
Another vote for the Tekonsha P2. We are customers of CanAm and they advised us that the P3 is not required and of little benefit over the P2. We have a 2015 Touareg TDI that we bought last March and I also performed the wiring myself utilizing videos like the eTrailer one. I purchased the wires and plastic wiring housing from my local VW dealer as recommended. Works perfectly pulling a 25FB.
travco72 is offline   Reply With Quote
Old 09-09-2020, 03:55 PM   #9
2020 20' Bambi
Laguna Beach , CA
We have a new Curt Echo Bluetooth brake controller, and after 5 trips and 2500 miles I am not happy with this controller. Even after making the fine tuning adjustments to the settings, it still locks and jolts when coming to a stop at slow speed. I'm now thinking of installing a hard wired brake controller as this problem seems to be caused by the millisecond bluetooth delay in the signal to the trailer brakes.
Any suggestions for a dependable, smooth performing hard wired brake controller for a 20' FB?
Calisurfer is offline   Reply With Quote
Old 09-18-2020, 11:57 AM   #10
2019 22' Sport
There is no Bluetooth communication to the controller when pressing the brake. The only time Bluetooth braking comes into play is the manual brake button on the phone when the brake pedal is not depressed.
I do agree that the small jolt at 3-5 mph is annoying.
Old 09-18-2020, 12:19 PM   #11
Mollysdad's Avatar
I have what I consider to be the industry standard, the Tekonsha Prodigy P-3 and I also get a jerk when touching the brakes at walking speed, like in heavy stop and go traffic. I look at the voltage and it doesn't seem to be any more than other times.
I've been using the manual shift to minimize touching the brakes.
Old 09-18-2020, 12:49 PM   #12
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I've been using the TruControl Gold, set it once at the start of the trip and it's done. I haven't had to re-adjust again unless the load changes. 👍
Ive always thought that over planning was just a firewall against not being sure of what you really want to do.
RLC
Tahawus
Old 09-18-2020, 03:20 PM   #13
2019 25' Flying Cloud
Hendersonville , North Carolina
Vote for Tekonsha P2
Plenty good for your application. Simple, inexpensive and works well. Available on the Wallyworld website for $133.00 and free shipping. It is what I have used for 4 years and I just ordered one for my friend to go into his 2020 Nissan NV3500SL van. I also scored the direct plug and play adaptor harness for
$15.00 again at Wallyworld.
uraljohn is offline   Reply With Quote
What Brake Controller Are You Using On Hydraulic Brake Classics? KJRitchie 2006 - 2010 Classic (all lengths) 30 09-25-2014 12:03 PM
Brake lights, brake controller not functioning adwriter73 Brakes & Brake Controllers 17 01-16-2014 09:37 AM
E53 w/ Tekonsha brake controller lights 3rd brake light when manual lever applied warmrain Brakes & Brake Controllers 10 11-14-2013 09:35 AM
Brake controller or trailer brake problem? (newbie alert) jornvango Brakes & Brake Controllers 2 11-01-2012 02:17 PM
New F150 '09 brake controller vs. Prodigy brake controller dukester Brakes & Brake Controllers 17 01-20-2009 10:46 PM
