Trace the output wire from the switch as far as you can. It should enter the belly pan close to the front of the trailer. There may be an access plate there. If so remove the plate and you should find the umbilical cord wires and the wire from the breakaway switch connection there. You want to connect the switch wire to the brake wire in the umbilical cord. If the connection is not there it may be directly above the floor.
2004 Excursion 4x4
