RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-11-2019, 01:49 PM   #1
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Bleeding Disc Brakes
I just bled my Kodiak disc brakes by myself in 30 minutes and used a pint of fluid. Thanks to the lift kit I could shinny under the trailer to get to the bleed screws without jacking it up.
The big secret is a pressure brake bleeder. I bought it for car use years ago and it worked fine but I haven't used it in a while. I tried to use it when we installed the disc brakes but I couldn't get it to pressurize the actuator. I had to get a replacement fluid reservoir cap and modify it to connect a hose from the bleeder. There was a tiny vent hole in the cap I didn't notice. With that sealed up everything worked great.
The bleeder is essentially a small garden sprayer with a pressure gauge. You put fluid in it and pump it up to 10 psi. Then you can go around to the calipers, crack the bleed screws and let the fluid run out until there are no bubbles. The actuator never runs out of fluid because the bleeder continues to force more in.
Here's a picture:
Name:	Brake Bleeding.JPG
Al
Can the drum brakes be changed to disc brakes? MOS Brakes & Brake Controllers 56 10-29-2020 05:27 AM
Rust bleeding on hubcap on new trailer bjmiess Wheels, Hubs & Bearings 9 06-27-2015 08:59 PM
Bleeding from small plastic coated Tarp on Polished surface brodjeaw Cleaning, Stripping & Polishing 2 09-24-2013 10:07 AM
Bleeding the LPS Tank Don Landis Argosy Motorhomes 5 11-16-2009 12:32 PM
Bleeding Brakes ljmiii Brakes & Brake Controllers 13 08-18-2008 09:12 PM
