Old 08-17-2021, 02:25 PM   #1
2021 20' Basecamp
Boca Raton , FL
Basecamp 20X Brakes Locking
We are new to Airstream. Our recent purchase of the Basecamp 20X has been and will continue to be a fulfilling experience. We trailered a boat for 20 years and we are well versed with towing.
We took delivery in February of 2021 and began our journey from SE US to NW US in May. We are using a Curt Bluetooth brake controller and after 2800 miles the brakes began locking up while coming to stops at lights. The apps was reinstalled, setting adjusted and finally a new brake controller was sent from Curt. The problem persist. My tow vehicle is a full size Range Rover. Does anyone know of a fix?
ETC51 is offline   Reply With Quote
Old 08-17-2021, 02:31 PM   #2
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
I would *guess* that this is more an issue with the brake controller than with the Basecamp. The Curt Bluetooth device is a bit unusual. No idea what might be wrong with it.
Old 08-17-2021, 02:35 PM   #3
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
ETC51,
Any chance to do a test tow with a completely different tow vehicle?
Good luck and keep the info coming.
Gary
GCinSC2 is offline   Reply With Quote
Old 08-17-2021, 03:20 PM   #4
2017 25' International
West Lake Hills , Texas
Just a thought…probably not a very good one…
After stopping somewhere safe where the problem occurs (empty parking lot), could you disconnect the 7-pin and see if the brakes release? That might confirm that it is brake controller.
Fungus is online now   Reply With Quote
Old 08-18-2021, 11:37 AM   #5
MMCMRET's Avatar
2021 25' Flying Cloud
Fredericktown , Ohio
Something Similar in Another Thread.
A similar type discussion is happening on this thread. https://www.airforums.com/forums/f44...m_medium=email
Maybe it will help. Several ideas being tossed around.
Good Luck.
Todd Mizer
2021 25' FBT Flying Cloud
Ford F-250 6.7L
WBCCI #6826
We have Year-Round Courtesy Parking.
MMCMRET is offline   Reply With Quote
Old 08-18-2021, 03:06 PM   #6
As noted...inspect the brakes first. Electric trailer brakes can have issues all their own.
For some reason I would be bit uneasy of BT controlling my AS brakes.
If my wired unit fails it's much easier for this OF to diagnose &
repair.😂
Is BT being used because a wired version is difficult to wire or nonexistent?
“I’m not an expert, I’m just a loose association of thought.”
RLC
It's that time again... Have a great Happyhollowgivingthankmas everyone.
Old 08-19-2021, 12:38 AM   #7
2021 20' Basecamp
Boca Raton , FL
Brakes Locking
All your comments have very helpful.We leave on August 22 for 4 days, Its a short drive. Best we were able to coordinate with AS for service is next month. Reading through the threads has prompted a visual inspection of the brakes before departing. A second set of threads had described some similar situations and when the drum brakes were inspected it became evident, the issue was with the brakes assembly. I'll pass on my finding. At times I've been so tempted not to use a controller, not a good idea. Nothing worst than feeling that tug when you approach a light. Letting off on the TV brakes helps plus allowing a greater distance to stop. Thanks again to all.
Hitch height for a Basecamp 20X ptiemeier Towing, Tow Vehicles & Hitches 1 06-27-2021 02:49 PM
2021 Basecamp 20X Black Oak Towing, Tow Vehicles & Hitches 2 04-14-2021 06:08 PM
Towing basecamp 20x w Jeep Grand cherokee kgottleib Towing, Tow Vehicles & Hitches 15 10-17-2020 01:21 PM
Basecamp 20X and Sway Bars Lintcj Base Camp 10 08-12-2020 12:50 AM
WTB (want to buy) - Locking Pin + Chesler T-5 Locking Pin Billyjchase Doors & Locks 10 06-29-2020 09:16 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
