Old 03-14-2019, 08:48 AM   #1
Celebration , 34747
Another Newbie Brake Controller Question
Getting ready to start towing my "new" 1989 29' Excella. Everything I read tells me I'll be sorry if I don't install a brake controller. However, the dealer says it's already installed with the tow package in my 2019 Armada.
My instincts tell me to go with the dealer's response, but I want to be as safe as possible. So, Airstream experts, what's the correct answer?
THanks.
donmcdonald is offline   Reply With Quote
Old 03-14-2019, 08:51 AM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
If your tow vehicle comes with a factory-installed trailer brake controller, you do not need to install and after-market unit. You should be all set to go in the trailer brake department.
Brian
SuEllyn & Brian McCabe
2020 Silverado 2500 (Vivian)
Old 03-14-2019, 09:02 AM   #3
AirMiles's Avatar
2018 27' Globetrotter
Apollo Beach , Florida
My two Nissan Titan XDs had factory installed Tekonsha Prodigy break controllers. I hope your Armada also has one. It should be within easy reach of the steering wheel and have a digital readout with a red dot (or two) when not connected and a "C" when connected. It should have a lever that can be used to manually engage the trailer brakes and an up/down arrow to adjust the braking level. Mine was dash mounted on the right side of the steering wheel.
On some of my other Nissans, the trailer tow package included the wiring but not the brake controller. There was a plug under the steering wheel (attached to the steering column) that had about six pins. I bought a Tekonsha Prodigy brake controller and the adapter wire from Tekonsha to insert directly into that Nissan plug attached to the steering column.
Bottom line, look for the brake controller push lever and digital display on the dash. If you have one, you are all set to tow.
2018 GT27Q, 73 nights 12,177 miles, 600W Solar - 110kWh, PD4655L, 6V Batteries, Blue Ox, 16" tires, 2019 F250 PSD
Sold: 2017 FC25FB, 316 nights 40,150 miles, Propride, 400W Solar - 200kWh in 216 days
2013 Casita SD17 89 nights 16,200 miles
(O+5200)
AirMiles is offline   Reply With Quote
What Brake Controller Are You Using On Hydraulic Brake Classics? KJRitchie 2006 - 2010 Classic (all lengths) 30 09-25-2014 12:03 PM
Brake lights, brake controller not functioning adwriter73 Brakes & Brake Controllers 17 01-16-2014 09:37 AM
E53 w/ Tekonsha brake controller lights 3rd brake light when manual lever applied warmrain Brakes & Brake Controllers 10 11-14-2013 09:35 AM
Brake controller or trailer brake problem? (newbie alert) jornvango Brakes & Brake Controllers 2 11-01-2012 02:17 PM
New F150 '09 brake controller vs. Prodigy brake controller dukester Brakes & Brake Controllers 17 01-20-2009 10:46 PM
