Greetings Larry!
Welcome to the Forums and the world of Vintage Airstream ownership!
Originally Posted by Burroman
I have a ‘56 Airstream Bubble.
It came with defunct hydraulic brakes, no electric brakes.
I’ve put electric brakes on it and am wiring it up.
I follow the connecting cord from the plug into the body but can’t seem to locate where it is inside the trailer.
I need to run my 10 gauge wire to the brake terminal on the 7 way plug.
Anyone know where I can access the tow vehicle wiring?
Larry
I am not certain that I am completely following what you are trying to do, but I will try to offer a few suggestions.
First: If you are looking on the trailer side, don't be expecting to find wires that correspond to the standard colors now used in the 7-wire umbilical cable as those standardized colors were not adopted until some time in the early 1980s.
Second: The junction box for the trailer running/exterior lights varies somewhat from year to year and could vary according to which factory the trailer was came from -- California or Ohio.
Third: There is little predicting what prior owners may have done to the trailer's wiring so you never know where you might find its current junction box, or what color and type of wire may have been used in modification/repairs/replacements.
Based upon what I have seen in Airstream trailer of this era, I have two guesses of places to look for the junction box. Starting from where the umbilical cord enters the front of the trailer, look at the bellypan. What you are looking for is a rectangular or square panel that is between 8" X 8" and 10" X 10" -- that often covers the below floor junction block for the umbilical cable in trailers of this era. The second location that I have seen, also on trailers of this era is a junction block mounted on the interior wall below the front window in the storage area under the front sofa -- it may be behind the pressure water tank so difficult to see if you aren't looking for the junction block. I am sure that there are probably other possible locations as the factory wasn't necessarily consistent from year to year nor between factories.
A number of us with Airstreams of this era have found that all of the umbilical wiring exiting the junction box is all red with knots in each wire, and the number of knots in the wire indicated its function.
Good luck with your investigation!
Kevin
