Old 04-05-2020, 09:03 PM   #1
1974 Argosy 26
West Des Moines , IA
74 Argosy brake job and grease bearing
Im thinking about trying to take this job myself. I have swapped pads on my disc brakes for years with adequate results. Any tips of things to do or avoid? Should I hire this done? I've never packed bearings before either.
Thoughts?
Other things that I've done before to demonstrate my mechanical ability.
Swapped out alternator, spark plugs, and starter F150
Brakes on multiple vehicles
natedogg7 is offline   Reply With Quote
Old 04-05-2020, 09:33 PM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Bearing repack is pretty straight forward. Can of grease and new grease seal is all you need. There are plenty of instructional videos online. There are tools to help pack, but I prefer to use the grease in the palm of the hand method.
Brakes on a 74 most likely need shoes, magnets and maybe springs. I would suggest replacing the entire unit by installing new backing plates. Yours should be 2" x 12", but I am not positive. ETrailer is a good place for parts.
Richard
azflycaster is online now   Reply With Quote
Old 04-06-2020, 04:56 AM   #3
1976 Argosy 28
Buford , Georgia
Make sure you don't forget the gloves, it gets quite messy and do one wheel at a time (so you have one to reference to).
strangepod is offline   Reply With Quote
Old 04-06-2020, 07:04 AM   #4
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I've installed the self adjusting brake assemblies with good results. However, I recently had new axels installed and, of course, new brake assemblies were included. I had the choice of manual or self-adjusting. I went with manual because there have been a rash of failures of the self-adjusting brakes. I know several that have had problems with them on new Airstreams. I've been very happy with the self-adjusting assemblies that I had installed but that was 5-8 years ago. So, check around and see if they are continuing to have failures and avoid them if they are. The failures are internal parts breakage and the wheel locking up.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 04-06-2020, 10:42 AM   #5
2006 30' Classic
1966 20' Globetrotter
Dover , Delaware
Check out Eastern Marine for your brake assemblies. They have very competitive prices and sell Dexter OEM brakes not Chinese. They carry several thousand in stock.
helwigc is offline   Reply With Quote
Old 04-06-2020, 11:35 AM   #6
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
I bought an inexpensive bearing packing tool, works quite well, you can just pump the fresh grease in. I had trouble with the self adjusting breaks, so I switched them back to manual they get checked and adjusted once a year when I repack my bearings. I do carry the adjuster tool with me, but haven’t ever needed it, on the road.
bibbs is offline   Reply With Quote
Old 04-06-2020, 11:47 AM   #7
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I do it myself. But..... it is a pretty dirty job. And I am getting too old for it. So I have been thinking. If you could find a local shop that would do it that would be a real luxury. Pretty easy job for a real mechanic. Maybe a mobile service to do it in your driveway? The potential to save a good bit of money is there if you do it yourself. The 2 lockups I personally heard about and saw were actually Dexter brakes instead of the e trailer brakes. From the brakes falling apart. Not from over adjusting.
The last time I put on the assemblies from e-trailer. I dumped the bearings they sent and used timken USA bearing ordered from Amazon. I expect that was not really necessary. To my slight surprise the self adjusting worked just fine all summer.
The trouble I had and still have is in the connections of the brake wire. The trailer wire is big. The brake wire is small. I think you either have to special order connectors for a large wire on one end and a small one on the other or to use an intermediate sized wire in between and 2 connectors. That problem is going to be there whoever does the brakes though. Over the years I have had Airstream shops reconnect the brakes and those came loose eventually too. Those who think the TV stops the TV and the trailer stops the trailer better not pull and old Airstream.
I thought I did a good careful job on the wires and 3 out of the 4 came loose or lost connection before the summer was out. I will redo the wiring again before we head out. Maybe someone will give us some pointers on this thread.
Bill M. is online now   Reply With Quote
Old 04-06-2020, 11:54 AM   #8
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
It may not be a glamorous repair but if you can jack and support the trailer and make it a DIY project you will learn a lot and you can check off trailer brakes as a been there can do it task.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 04-06-2020, 03:12 PM   #9
1976 24' Argosy 24
1999 30' Excella 1000
White Haven , Pennsylvania
Ditto with replacing the entire assembly. Price wise it works out very close to buying magnets and shoes, and then everything is new. 4 bolts off, connect wires, 4 bolts on. Done. Bearing wise, not hard. Messy yes.Be sure to get new seals.
Gkiesel is offline   Reply With Quote
Old 04-06-2020, 04:47 PM   #10
1974 Argosy 26
Got er done, a friend of mine had done it before and it took about 3 hours of work and an hour driving to part stores.Thanks all. I did learn a lot, I assume next time will be when an axle fails.
Old 04-06-2020, 05:26 PM   #11
2002 25' Safari
Dewey , Arizona
Images: 62
I think 5 bolts is correct.
These could be the proper brakes. Please verify...
https://www.etrailer.com/Trailer-Bra...3-180-181.html
Richard
Old 04-06-2020, 11:00 PM   #12
bibbs's Avatar
1975 26' Argosy 26
Vista , California
When connecting the smaller wire into a larger connector, simply strip off one inch of insulation from the thinner wire, and fold it back on itself, then insert and crimp. Always try to pull the connection apart when done. Then you know it’s good.
Old 04-07-2020, 07:05 AM   #13
2013 20' Flying Cloud
Westerly , Rhode Island
I use a simple barrel crimp connector and heavy duty waterproof heat shrink over it extending an inch or two on each side. Keeps them from coming loose and corroding.
smithcreek is offline   Reply With Quote
Old 04-07-2020, 07:59 AM   #14
2019 27' Globetrotter
Missouri Valley , Iowa
I would add to the suggestion list to get the self-adjusting type of brake back plates. A few bucks more but well worth it in my opinion. Its a fairly easy job to replace them.
Dan
Farmer Dan is online now   Reply With Quote
Old 04-07-2020, 08:46 AM   #15
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
My vote is for manual adjusted brakes.
I have a 5 year old SOB that had self adjusting brakes. Nothing but trouble.
Just installed manual adjust brake assemblies.
Old 04-07-2020, 06:35 PM   #16
1967 26' Overlander
Spartanburg , South Carolina
Thoughts?
Assuming you have Dexter axles and want to replace worn brake shoes, google Dexter and find the nearest Dexter dealer. Purchase new backing plate assemblies complete with new magnets, shoes, springs, etc. at about the same cost as buying the components and doing all that yourself. Repacking bearings is simple with a cheap tool from Harbor Freight or almost any automotive store. I usually clean my bearings in a good solvent without turning them, blow dry and pack with any good quality bearing grease. Then turn the bearings by hand to make sure all bearing components have some grease on them and there are no rough spots. Do not fill the hub space between bearings with grease as some do because too much grease is the greatest cause of bearing failure from the heat generated by churning.
Jacob D is offline   Reply With Quote
Old 04-08-2020, 01:42 PM   #17
bibbs's Avatar
1975 26' Argosy 26
Vista , California
A good crimped connection should not come loose under any situation. Again I say try to pull it apart, give it a good tug! Then heat shrink seal it
Old 04-24-2020, 08:23 AM   #18
2002 34' Classic S/O
sault sainte marie , Michigan
Totally agree azfly: replace the entire backing plate, it is about the same cost as the shoes alone and you get all new springs, adjusters, and shoes. Then you also have some spare parts for future minor repairs. Also agree with the palm-pack method. Additionally, fill the hub as full of grease (I use the Airstream-recommended Valvoline Red). Then install Bearing Buddies, and add grease untill the spring-loaded cap inside the Buddy moves outward. I carry a grease gun with me, and add a few pumps every thousand miles or so. Don't forget the Bearing Buddy Bra vinyl caps, as they keep dirt out. I also wrap the Bra with black electrical tape to the Buddy so it doesn't get lost. Also, drive those Buddies on there with a big hammer and a block of wood so you don't lose them. When they get lost, you get a greased-up side of the Airstream.....ask me how I know.
bartzstream2 is offline   Reply With Quote
Grease or No Grease? banderabob Towing, Tow Vehicles & Hitches 11 05-05-2019 09:17 PM
To grease or not to grease Grand Master Hitches, Couplers & Balls 16 04-19-2009 01:45 PM
Big Job turned into bigger JOB, need advice. lebolewis Waste Systems, Tanks & Totes 10 11-16-2006 05:28 AM
Mobil 1 bearing grease.......... Mike76251 Axles 0 10-06-2003 07:33 AM
Synthetic Wheel Bearing Grease Pick Axles 4 11-24-2002 08:18 PM
