Old 11-09-2024, 01:04 PM   #1
Owens Cross Roads , AL
'63 Bambi brake drum swap
Greetings, I've just bought a Bambi from a friend and will be picking it up in a couple of weeks. It has old B78-13's on it now but I would like to use 14 inch tires instead. Has anyone swapped out the original drums to later model 5 lug drums? I was hoping to use 185-70-14's on it if possible.
Clarke33 is offline   Reply With Quote
Old 11-09-2024, 02:03 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 196
RE: '63 Bambi Brake Drum Swap
Greetings Clarke33!
Welcome to the Forums and the world of Vintage Airstream ownership!
Unless I am mistaken, the 1963 Bambi came with Henschen DuraTorque torsion axle, and assuming that it is original, it is well beyond time for replacement. With that as a consideration, my suggestion would be to get a pair of tires to get your through to axle replacement as your new axle will include complete braking assemblies and all you will need to purchase in addition at that time will be new wheels and tires of your choice.
For more information about the DuraTorque axle and how to tell when it is time to replace, check out the following document:
DuraTorque Axle 101 -- Inland RV
https://www.airforums.com/forums/att...0&d=1719286823
Good luck with your Bambi!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC/Pride Streamers/Wisconsin-UP Unit (Primary)/Missouri Greater Ozark Unit (Affiliate Member) #7864
AIR #827
1964 Overlander International
Old 11-09-2024, 03:40 PM   #3
Thank you for your information! I'm totally new to the airstream scene and trying to learn all I can about the Bambi. I got it for what I think is a very good deal so I definitely plan some upgrades. I'll post pictures as soon as I pick it up but it is a one family owned and is very straight.
Hadco Brake Drum rfcjr Brakes & Brake Controllers 3 10-22-2011 09:19 PM
Cracked Brake Drum gwchitty Brakes & Brake Controllers 3 04-12-2008 04:09 PM
Need easy way to take brake drum off..>> Mrcrowley Brakes & Brake Controllers 18 05-23-2006 09:44 PM
Trailer brake drum sizes? Mike B Brakes & Brake Controllers 3 06-08-2005 10:16 AM
Need Help –Brake Drum HOT! Mookie Brakes & Brake Controllers 12 05-21-2005 10:36 AM
