Old 09-07-2020, 09:00 AM   #1
2018 19' Flying Cloud
Eugene , Oregon
Valve stem replacement
I bought a TTS tire monitoring system... and after putting them on the tires of my 2018 19í Flying Cloud, I took them off again to check something. When I did that one of the valve stem cores began to leak. The only way to stop the air from rushing out was to put the cap on. I now will have to replace the stem valve core. My question is - is there a specific stem core valve size for the 15Ē Goodyear Endurance Tires? Can I just go to Walmart and buy a stem valve replacement tool kit that will work on the trailer tires (as opposed to car tires)?
tjwoods1 is offline   Reply With Quote
Old 09-07-2020, 09:11 AM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Metal?👍
I'm not sure what diameter you need,(our OEM Alcoa wheels came with metal stems), but you will need stems matched to the hole size to support the TPMS sender.
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Mary-Jane....'cuz 2020 sucks"
Tahawus
Old 09-07-2020, 09:25 AM   #3
Eugene , Oregon
I think I just need to replace the valve core
Old 09-07-2020, 09:30 AM   #4
Mollysdad's Avatar
Just replace the valve core.
What you said is not what people heard.
Old 09-07-2020, 09:39 AM   #5
Sorry... I did not realize that your wheels came with metal valve stems. 🥴
The valve core has no relation to tire brand.
Molly Ivins
Tahawus
Old 09-07-2020, 08:04 PM   #6
Eugene , Oregon
It turns out that in removing the TST sensor the valve stem core came loose. All I needed to do was tighten the core stem and the air stopped flowing out.
I am unsure if my 2018 has metal stems or not. The top part is metal but the base looks to be rubber. Donít the metal stems have some kind of metal bolt at the base ... and that is what distinguishes it from the rubber.
Attached is a photo of my stem.
(This is the 2nd time Iím sending this ... I didnít get a confirmation that my reply went through) If it did I apologize for the double post.
Old 09-07-2020, 09:25 PM   #7
2013 30' Flying Cloud
Kingwood , Texas
Yes you have rubber valve stems.
DoubleR is offline   Reply With Quote
Old 09-08-2020, 06:37 AM   #8
Ok..so now we are back to replacing the rubber valve stems to properly support the TPMS senders.
So I guess what I heard was what I heard.😂
You will need to know the diameter of the stem hole to get the correct metal stem. Many here have done it, they should be able to help with the Dill part number.👍
Molly Ivins
Tahawus
Old 09-08-2020, 07:57 AM   #9
Mollysdad's Avatar
What you need is the Dill 902 W stems.
Your valve stem is recessed in that machined area, so a standard valve stem won't fit. The 902W has a shoulder nut, meaning the hex part will be raised above the recess.
Discount Tire is a good source. They're about $5. If you have any tire store do it, be there to show them where it's safe to jack. Better yet, take the wheels there yourself.
(My DT had good techs, but he wanted to jack on the pan, thinking it was the frame.)
Originally Posted by ROBERT CROSS View Post
So I guess what I heard was what I heard.��
"Everybody's a critic" -- Arthur Fiedler (at the Boston Pops when an elephant dropped a load behind the conductor's stand on circus night.)
Old 09-08-2020, 09:10 AM   #10
Is a critic always rong?
I just realized that what I read I understood...sorry for any ego assault.😥
Molly Ivins
Tahawus
Old 09-16-2020, 04:16 PM   #11
BTCMUSN's Avatar
2018 27' International
Tyler , Texas
I just bought 5 - Dill VS-902-W metal stems @ $1.69 each from McGee Company out of Dallas. Phone is 214-689-0400. They overnight mailed to me for $6.00. Then you can take them to any tire place and get them installed. Highly recommend...
2018 International Signature CCD 27FBQ/Centramatics/Hensley Arrow 1400#
2017 Ram 3500 6.7 Cummins TD Longhorn Laramie MegaCab/Centramatics
WBCCI#11290
US Navy (ret) Master Chief Boiler Technician
BTCMUSN is offline   Reply With Quote
Old 09-22-2020, 11:53 AM   #12
2015 25' Flying Cloud
Bettendorf , Iowa
So I am having my tires changed Click image for larger version
ID:	379256on my 2015 25í FC. I would like to install metal valve stems which I believe would be the Dill VS 902w stems. I see members reference the Sendal T-2 rims but I have no idea which rims are on my AS and I donít see any marking on the rim or reference in manuals.
Any thoughts?
Rltports is offline   Reply With Quote
Old 09-22-2020, 12:54 PM   #13
Mollysdad's Avatar
Originally Posted by Rltports View Post
So I am having my tires changed Attachment 379256on my 2015 25’ FC. I would like to install metal valve stems which I believe would be the Dill VS 902w stems. I see members reference the Sendal T-2 rims but I have no idea which rims are on my AS and I don’t see any marking on the rim or reference in manuals.
Any thoughts?
Yes. Those are the Sendel T-2. Same as mine. I just went to the Sendel web site and looked over the rims.
And, yes, I installed the Dill 902-W in those very rims.
The Dill stems are available at most Discount Tire Stores. Call first.
Here's my post on doing it yourself. (I don't recommend it, but I'm glad I did.)
https://www.airforums.com/forums/f31...ms-183020.html
Old 09-22-2020, 01:21 PM   #14
Bettendorf , Iowa
Thank you Mollysdad.
Yes I called Discount Tire and they have them. As far as changing them myself, Iíll pass on that.
Just an FYI, I decided to change the tires based on comments from other members. They are 5 yrs old and it is worth it to me if I can avoid a blowout. As for the new tires I opted for the Goodyear endurance E rating.
There are a lot of discussions about tire choices but Iím am cautiously hopeful these will prove ok. Time will tell.
Thanks again for the quick response.
Metal valve stem replacement Norrie46 Wheels, Hubs & Bearings 1 07-02-2019 12:47 PM
Sprinter 3500 Dually Interior Valve Stem Replacement wildwilly. Sprinter and B-van Forum 5 05-18-2018 05:44 PM
Valve stem replacement Dan S Tires 3 05-24-2014 05:28 PM
Replacement cartridge valve stem for my Moen shower, Help???? jerrodwong Plumbing - Systems & Fixtures 4 09-10-2006 08:42 PM
Valve stem Craig Wheels, Hubs & Bearings 1 08-04-2003 05:34 PM
