Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Tires
Old 12-08-2007, 08:52 AM   #21
jkcru's Avatar
2010 28' Flying Cloud
Escondido , California
Outside wear could be indictive of low air pressure.
jkcru is offline   Reply With Quote
Old 12-08-2007, 09:05 AM   #22
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
My Marathons looked very similar. Changed tire brands and with nearly 50,000 miles on the new tires, they show NO uneven wear patterns. It's just Marathons!
So Long!
Bob Thompson is offline   Reply With Quote
Old 12-08-2007, 09:16 AM   #23
startrekker2001's Avatar
1978 31' Excella 500
Palm Bay , Florida
Images: 34
Tire Wear
I had a very similar problem with my 78 31' Excella. The tires on the road side were wearing and cupping. The only solution I know that works is to take it to the factory and have them align the wheels. It is an interesting process where they hook a come-a-long to the axle and bend it, bringing it into alignment.
Once I had this done, I have had no further problems with tire wear. You may be able to find a dealer that can do the alignment, but for sure the factory will do it and do it right.
Vic
Vic Smith
Director Florida State Rally
www.floridastaterally.org
www.facebook.com/FloridaStateRally
WBCCI Florida Unit 027 Trustee
https://www.airstream-adventures.com/...rida_Unit.html
WBCCI #6782
31' 78 Airstream Excella 500
2001 Ford Excursion V-10
Reese hitch and dual cam sway control
startrekker2001 is offline   Reply With Quote
Old 12-09-2007, 09:56 AM   #24
claybags's Avatar
2007 25' Safari FB SE
rio rico , Arizona
It looks like I have excessive toe-in on the front curbside wheel, the one that shows the most wear. I've always checked pressures before going on the road, so I ruled that out. Still need to talk to AS dealer in Tucson before jumping the gun here. A trip to Ohio is not in the cards for a thousand reasons($$$$$ and weather). When new tires are necessary, I will definately look at other brands. I, along with many others I'm sure, am getting tired of all the Chinese crap foisted on us by greedy manufacturers. At least there's no lead in my tires( I'll leave it at that!! )
Cheers, Jeff
2007 Safari 25 FB SE LS
2006 Chev Express 3500 Duramax
Predator tuner
Equal-i-zer hitch
"Home is where the ART is"
claybags is offline   Reply With Quote
Old 12-09-2007, 10:37 AM   #25
HowieE's Avatar
Princeton , New Jersey
Images: 12
Before you go to the dealer for work see if you can find a TRUCK AXEL shop. These axles require rebending to aline them. That takes equipement that Jackson doesn't even have as I can attest to from first hand experinece. Picture show my trailer in a shop in Pa. for an alinement after the installation of new axles.
2004 Excursion 4x4
Old 12-11-2007, 09:23 PM   #26
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Vic
Cupping can be from out of balance running gear or weak shocks. The tire/wheel assy is bouncing as it travels causing uneven wear. The shock dampens the bouncing. The balance fixes the cause. This is not a tire design issue unless the tire (or wheel/hub assy) are grossly out of balance.
>>>>>>>>>>>Action
Old 12-11-2007, 09:26 PM   #27
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
This site may help.
HDT Tire Wear Chart pictures from trucks photos on webshots
>>>>>>>>>>Action
Old 12-11-2007, 09:46 PM   #28
Images: 67
Ok.........It's pretty easy to figure out what is wrong. Take a straight edge and place it across both tires on the same side, just below or above the center cap. This will tell you if you have a toe-in/out problem. Look at where the straight edge intersects each tire. There is a possibility the tires are coming apart and will read unevenly. This can be checked by jacking up the trailer and hand spinning the tire checking the sidewall for unevenness by using a stationary fixed point. I used a plastic pail with a stick laying across it. I set the stick about 1/16" away from the tire, held it in position, then spun the tire. If the tire was out of square, it would have shown up. The tire sidewall should always be the same distance from a fixed point when the tire is spinned by hand. With the info from above continue........ find the exact center point of the back of the ball opening at the trailer tongue, then measure very carefully from the exact center point of the back of the ball opening to the closest point of each wheel (usually the inside of the wheel rim. Measure very carefully. If the measurements are within 1/4", the alignment of the axles is probably in the acceptable tolerance range. Mine were the exact same dimension! And..... putting a straight edge across both tires on the same sideconfirmed there was no tow in/out problems. Proceed.
So Long!
Old 12-11-2007, 10:48 PM   #29
It's easier to use the center of the jack post.
On a 31 foot trailer, each 1/8 inch difference, will make the trailer, from front to back, tow about 3 inches "dog leg."
A 1/4 inch difference should make the trailer tow about 6 inches "dog leg," and so forth.
A better place to measure is from the center of the jack post, to the lowest leading edge of the axle mounting plates. That dimension should be "exactly" the same.
If that dimension is off, even 1/8 of an inch, then a different alignment procedure must be used to align the axles, since you would not have "exactly" a tandem axle setup, but more so a staggered 4 wheel suspension.
This was some what common in the early 70 and 71 trailers.
This can also apply to a single axle trailer as well.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 10-16-2008, 03:19 PM   #30
Sky
Classic 30
Sky's Avatar
Sum Wear , Ohio
Hey Jeff, did you ever resolve this problem? It sounds like I have the same issue. My tires had less than 10K on them when I noticed the problem. The front curb side Marathon was bald on the outside half. The other three tires looked fine. I was in the great state of Utah at the time, so I put the spare Marathon on and continued with the trip. I put about 2500 miles on the spare by the time I got home, but notice no unusual wear on it.
I made an appointment to have an alignment done at Jackson Center. I just got back from that appointment today, and they tell me I don't need an alignment, everything checks out OK. I keep my tires at 65psi and monitor them with Pressure Pro and a standard pressure gauge, so inflation pressure should not be a factor. We decided to watch the new tire carefully, and bring it back in to JC if I see the same thing happening.
Soooo, when I got home I started searching the forums and found this thread. I was wondering how your case turned out.
In this economy, I can't afford a new tire every 10K miles.
Dale
"Only dull people are brilliant at breakfast" - Oscar Wilde
2500HD DMax............30' Classic
Sky is offline   Reply With Quote
Old 10-16-2008, 04:10 PM   #31
Dale
Dale.
Abnormal tire wear for most part, is caused by lack of ptoper running gear balance, that is tire, wheel, hub and drum, as an assembly.
You can check the alignment yourself, with a ruler and straight edge.
Each tire should have a tow in of 1/16 inch, plus or minus 1/16 inch.
The bottom of the tires should be more inboard than the top of the tires, again, by a small amount of 3/4 degree plus or minus 3/4 degree.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 01-13-2009, 11:35 AM   #32
Eagle & Bear's Avatar
1976 29' Ambassador
Madison , Officially SD but are traveling full time.
Going through the threads because I am having problems with irregular tread wear. I found a comment in the AS owners manual. Their explanation for more wear on the curb side is that the "cant" or high center of the road throws more weight onto the curb side tires.
The tires on my '76 Ambassador are bias ply. Took the AS to the local tire shop and they said bias ply tires just wear irregularly and I cannot expect much more that 15K mi out of them. They are cheap but I don't like the poor level of quality in the product.
Anyone know how to check if the shocks are good?
Michael
Eagle & Bear is offline   Reply With Quote
Old 01-13-2009, 11:47 AM   #33
Michael
30 year old shocks should be replaced.
The running gear should be balanced as an assembly.
The axle could be out of alignment.
A bad axle could cause funny tire wear.
Check out your axles yourself, in 30 seconds.
Dura Torque Axle
Andy Rogozinski
Inland RV Center
Corona, CA
Old 01-13-2009, 12:21 PM   #34
1976 29' Ambassador
Hi Andy,
Thanks for the info. I did have new 8 ply bias ply tires put on 16 months (14,000 mi) ago. They seemed to wear OK but had problems with adjusting breaks. 8 months ago I had new backing plate assemblys installed and drums turned. Brakes work good but tires are all wearing in very weird patterns. Trailer towes good.
It looks like the axles have been changed sometime in the past (original owner died several weeks after I bought the trailer so no real history available). Clear evidence of alignment on rear axle. Tortion arms are slightly negative under load and over 20 deg neg without a load. There is almost 5" between the wheel well edge and the top of the wheel rim. The shocks dont have any rust on them (paint is in tact but not shiny). No signs of leaking from the shocks but the tire wear is irregular.
The tires do not show any signs of toe in or toe out but the tread shows a lot of cupping and heavy wear on the #2 and #4 band on a 5 band tread pattern (outer part of tread is cupped but not heavily worn and center band is not cupped or heavily worn - not consistent with over or under inflation). I thought I should check the shocks anyway but am not sure how.
Michael
Old 01-13-2009, 12:28 PM   #35
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Michael
Look at post 26 & 27 above.
>>>>>>>>>>>>>>>>>Action
Old 01-08-2015, 07:09 AM   #36
BeachHouse's Avatar
2005 25' International CCD
Lilburn , Georgia
Any thing new? Our 2005 25' International has high tire wear on the curb site on both tires. We do have GYM's. It is even across the treads. The street side tires still have plenty of tread left. The tires have been installed for 27 months. We figure we have about 20,000 miles on all of the tires (same age). Discount Tire had no answer. They suggested replacing the two worn tires and put the new ones on the back axle and then put the less worn street side tires on the front axle.
We have a TPMS since we got the new tires so I know the pressure and temps are consistent. We had been running at 65#, but recently have let them go down to 60# (opinion seems to vary as to whether to keep them at the max or adjust based based on load).
I would appreciate any thoughts?
BeachHouse is offline   Reply With Quote
Old 01-08-2015, 07:17 AM   #37
dznf0g's Avatar
Oswego , Illinois
Have you weighed the trailer side to side? Barring any pressure concerns and tire construction anomalies, weight is the only thing that comes to mind. You state even tire wear across the tread, so alignment is probably not the answer. Do you have pics?
-Rich-
Old 01-08-2015, 07:28 AM   #38
BeachHouse's Avatar
Lilburn , Georgia
Haven't ever weighed it. And it isn't loaded differently than it has been in the past. A trip to the scales is in order. We are always in a hurry to get where we are going and don't stop.
Old 01-08-2015, 07:56 AM   #39
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
regular weighing is good a idea
I CAT every outing, and use my Sherline during loadout
but, I've never come across scales that had independent curb/street side plates
are they available publicly?
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Old 01-08-2015, 08:53 AM   #40
dznf0g's Avatar
Oswego , Illinois
Just run across with one side off the platform, on the "shoulder" of the scale pad. Align the axles as you would normally do for a single side axle weights. Repeat for the other side.
-Rich-
Uneven tire wear Lumatic Tires 7 07-19-2012 09:08 AM
WD bars uneven load - equalizer hitch flmgrip Hitches, Couplers & Balls 16 05-25-2010 08:06 AM
Uneven (rutted) road surface dkottum Hitches, Couplers & Balls 6 11-11-2009 08:18 PM
uneven tire wear 64globetrot Axles 4 09-13-2009 02:01 PM
Uneven tire wear..Yikes!! daydreamer36535 Tires 18 07-09-2007 10:17 AM
