11-03-2002, 07:48 AM
1975 31' Sovereign
Eau Claire
, Wisconsin
ultra violet damage
Alas, my TT will now be sitting idle for some months.Do I need to be concerned about UV damage to my tires? If so is it simply a matter of covering them up? AS always, all sage advice will be weighed and considered. Thank you.
Brouck
11-03-2002, 08:38 AM
1965 20' Globetrotter
Houston
Tire Covers or a cheap tarp.
-BobbyW
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
11-03-2002, 09:10 AM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
a quick spritz of a good tire protectant with uv block will help if you don't cover them.
john
11-03-2002, 09:46 PM
Moderator dude
1966 26' Overlander
Phoenix
Dee Sun, Dee Sun
Brouck,
In the Valley of the Sun, (Phoenix) Bobby's advise is king. Anything short of a cover, of any type, will not cut it. I personnally use a piece of vinal roof material that was left over from a project that I did. It keeps the sunlite out and I didn't pay anything for it. And it has lasted for 5 years.
Anything that is light tight will work.
Now Bobby, that's not an Airstream!!!!!!!!!
>>>>>>>>>>>>>>Action
11-04-2002, 05:02 AM
1975 31' Sovereign
Eau Claire
, Wisconsin
tire togs
Thank you guys.It was not really something I had considered up here where maybe the snow will be above the axels before long but I was asked about it by another RVer and I trust the opinions of the majority of those taking part in the forums.
Brouck
11-10-2002, 03:00 AM
Mukilteo
up here
Brouck,,,you said "up here".; Were you indicating up North? and if you were, by that do you mean that being up north doesn't cause as much conern?
I'm going to make my covers before next spring. I haven't had covers or UV protection spray on mine; and it's been 'parked' for 3 1/2 years. Oh Oh! I'm in trouble eh? One is nearly flat.
Tomorrow I have a friend coming with a compresser to fill them all up;;;should set "hard" or not...? Like 85 psi ? or 75 psi ?
How can I tell if they have suffered damage from the sun? How much do new tires cost? I have a twin axle..so I'd need at least 2 for the outside?
or is that dumb to replace only 2? My GAWD...does everything hit at once!?
Is there a website http://www.rvtireexchangedforremodelingdesign.com/ ?
............Cat
11-10-2002, 05:55 AM
LOST
, Hawaii
Along with UV ozone also will deteriorate the rubber. When a tire is constructed a wax is added to the rubber. When it rolls and flexes it heats and the wax comes to the surface and helps protect the tire. Do you know how long they were on before you got the trailer? Just sitting 3 1/2 years is enough time to destroy them. There are 4 of them on 2 axles.
John
11-10-2002, 06:28 AM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
cat
make sure your friend with the compressor reads the information on the side wall of the tires before inflating them.
i doubt they get 85 psi...
are your tires cracked on the sidewalls? if not they may be o.k.
they should be "st" rated, you can find this info on the sidewall of the tire as well.
there are many other reasons why you have one tire lower than the others. bad valve stem or a nail in it. both can be repaired.
john
11-10-2002, 12:11 PM
Mukilteo
psi
Thank you John H.
That was good info..
I appreciate it...
Last night, I got a private email (on the Forum) from someone who said I aggravate members, because I don't read carefully...
and I just want to apologize to you all if I have.
jThis is just a small part of the message she sent me:
It's frustrating to people to spend their limited forum time directing others <<
Again, John ... thank you so much. I'll pass this info on to my friend.
..........Cat
11-10-2002, 01:05 PM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
cat,
no problem at all!
some of us may need to be reminded that not everyone is an expert.
i know i am not!
alot of this stuff is common sense and experience.....
mostly experience!!
i don't think your questions are out of line at all!
john
11-10-2002, 03:03 PM
Mukilteo
Nice people & ?
Thanks John...my Daddy told me to ignore Whiners and give my friendship and energies to those nice people...You are one of those nice people...
thanx again.
Bobby,,,,what are your tire covers made of? and how much did they cost? I bought some material & cord to make my own...and I want to know if its worth my effort...or if I should just buy some in the meantime...Can you get some cheap...? someone mentioned just using a piece of tarp...Tacky but it'd work...You can get a tarp in Silver/Grey colour which would look good on the permanent ones
Do you cover both tires on twin axles...? or just the top on both..?
or just the outside tire only.?
Thanx for the photo..
......Cat
