10-24-2020, 10:06 AM
2017 30' International
Lincolnwood
Truck Tires
Time for new tires for my Ford F-250 diesel.
What brand of tire, size, and model of tire are you running on your 3/4 ton truck and why?
All help-comments appreciated.
10-24-2020, 10:19 AM
2007 30' Classic S/O
Somewhere
, South Carolina
Might want to let folks know if 2WD or 4WD.
10-24-2020, 02:23 PM
2007 25' Safari
Rogers
, AR
I used a narrow Toyo Open Country MT 255/85R16.
Lots of debate on "Pizza Cutter" tires but my factory wheels were 16x6.5" and 255 was the widest tire rated for a 6.5" wheel.
Wider tires put more stress on the steering components (as I found out) and ballooned tires negatively impact handling.
I opted for the 33" tires because the truck had a small lift.
I chose MT because that was the only option in this size.
No complaints towing and had a great time off-roading while camped in Colorado.
2007 Airstream 25FB Safari LS - GY Endurance Prodigy Wireless - Andersen
2005 Chevy Silverado Crew Cab 2500HD Duramax Allison
2008 Porsche Cayenne Turbo 500hp/516lb-ft
2014 Porsche Cayenne Turbo S 550hp/553tq
2005 GMC Sierra Crew Cab 5.3L built 4L60e, 40k Tru-cool
10-24-2020, 02:50 PM
Broomfield
Truck Tires
Just installed bfg KO2 DT. The “DT” variant (only available in load range E sizes) have a harder tread compound for heavy 3/4 and 1 ton trucks reducing wear (as compared to the regular KO2). 50k mile guarantee. These are also slightly better for towing as compared to the standard KO2 in that there is less flex in the deep tree blocks under heavy load.
I chose these because I wanted a very capable, tough AT tire that was quiet, longer lasting and performed well in all seasons here in Colorado. These are not 3 snow flake rated due to the compound used (slightly less flexible below 40 degrees) but maintain their M+S designation.
To my surprise after install they really softened up the ride compared to the OEM tires that came off.
I am very happy with the change. No noticeable difference in handling.
If I was looking for a regular highway tire Michelin Defender would have been my choice.
10-24-2020, 03:10 PM
2019 27' International
Western NC
, North Carolina
Ditto experience with same KO2s
2023 Van Leigh Vilano 320GK
2019 International Serenity 27 FBQ “TC Escape” SOLD
2019 Ford F-350 Platinum
10-24-2020, 03:32 PM
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
, Texas & Wyoming
Michelin...hands down.
Been there, done that...so to speak! I am on my 3rd set of Michelins with my F250 diesel...just turned 110K miles...put 48K on my 28' AS also... I like the wear, the control, and they are not noisy on the road. LT275x65R20 is what I have been using since new. Rated very good for gravel road use also...which, we do use often when towing in the summer... Had to get these at Discount Tire since Costco was having trouble getting hold of them from Michelin. Discount Tire gave me better price then Costco even with their Michelin discount, plus they gave me a $100 cash card! I am happy with these...YMMV
10-24-2020, 05:56 PM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
I run the Michelin load range E. Good highway tire.
10-24-2020, 07:19 PM
Broomfield
Truck Tires
Which Michelins?
Which Michelins?
10-24-2020, 11:02 PM
Lincolnwood
4wd
10-25-2020, 07:54 AM
, Texas & Wyoming
Originally Posted by wulfraat
Which Michelins?
Which Michelins?
I have the Michelin LTX AT's.
11-25-2020, 09:53 AM
2017 30' Flying Cloud
Charlottesville
, Virginia
I have a Ford F-250 Diesel that will need tires. I was headed towards Michelin Defender route. Consumer Reports has nice things to say about the Continental Terrain Contact H/T. They rate them above the Defender. Does anyone have a comment on Continental?
11-25-2020, 10:08 AM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
I suggest looking at the temperature and the traction ratings of the tires. Wear ratings not as important to me. That is why I ended up with Michelins each time. Lots of good tires out there. But I go with what has worked for me. I do have a set of Wranglers with more aggressive tread on a little Toyoto 4 wheel drive that work fine too.
