Old 04-03-2019, 09:58 AM   #1
otorvund's Avatar
2018 22' Sport
ISSAQUAH , Washington
TPMS valve stem concern
What follows is a warning from the TireMinder web site:
quote
Brass vs Aluminum Tire Sensors
TireMinder Sensors
Your vehicle's tires will have either rubber or metal valve stems. RVs, motorhomes, 5th wheels, and trailers will generally have rubber stems with brass valve cores or metal stems with steel, chrome, or nickel valve cores - all of which work with the TireMinder brass sensors. This TireMinder kit comes with 6 brass sensors. You will only need aluminum sensors (TM-2ALUM - sold separately) if you're towing a car or light truck with built-in TPMS and aluminum valve stems.
It's important to choose the correct TPMS sensor for your vehicle. Pairing the wrong metals together may lead to galvanic corrosion, which makes it impossible to remove the sensors from the valve stem. If this happens, you will need to replace the valve stem or, in some cases, the whole tire. Matching the sensors to the construction of your valve stems will ensure the sensors won't corrode.
unquote
I have metal valve stems on my tires, but I can't tell if they are steel or aluminum. If they are aluminum I guess there could be an issue with corrosion unless the TPMS sensors are also made of aluminum. Or am I misunderstanding something /
09-08-2018 07:13 PM
otorvund is offline   Reply With Quote
Old 04-03-2019, 10:06 AM   #2
Sneakinup's Avatar
1977 31' Sovereign
Tampa Bay , ^
Images: 122
Check them with a magnet.
Out in the woods, or in the city, It's all the same to me.
When I'm drivin' free, the world's my home....When I'm mobile.
Sneakinup is offline   Reply With Quote
Old 04-03-2019, 10:53 AM   #3
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
quote
TireMinder Sensors
unquote
09-08-2018 07:13 PM
I expect someone will be worrying about this now... I personally have rubber, and TST system works fine for my needs. Other concerns about the AS when towing I think about; not this.
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Old 04-03-2019, 11:11 AM   #4
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
quote
TireMinder Sensors
unquote
09-08-2018 07:13 PM
..too much worrying...use a small amount of antisieze on the threads...it will come off easy in 30 years of use...most valve stems are brass....not alumiumn as the salt would eat it quickly...
Old 04-03-2019, 12:40 PM   #5
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
Yes, this. If in doubt, a little anti-seize on the threads will do the trick. For what's it's worth, I have never seen an aluminum valve stem. That said, I believe the threads on most TPMS are aluminum.
thewarden is offline   Reply With Quote
Old 04-04-2019, 10:08 AM   #6
2017 30' International
Lincolnwood , Illinois
Tpms
I 2nd the vote for anti seize.
I re-install my tpms every spring adding a little dab of anti seize.
Every fall I take them off. No problems.
Milo1952 is offline   Reply With Quote
Old 04-04-2019, 10:20 AM   #7
2017 19' International
Rosemere , Quebec
I apply Permatex Aluminum Anti-seize Lubricant on the valve stem before installing my EEZRV TPMS ��
Projet2907 is offline   Reply With Quote
Old 04-04-2019, 11:27 AM   #8
Mollysdad's Avatar
Much ado about nothing.
I remove the sensors every time I add air before a trip.
Galvanic corrosion is not a problem.
If you leave yours on for a year and live next to salt water, then "anti-seize" is needed.
Old 04-04-2019, 03:12 PM   #9
1999 28' Excella
Lake Mary , Florida
Tpms
whenever you install tire pressure monitors on your valve stems just follow this
1. Clean the valve stem threaded end with soapy water and an old tooth brush.
2. Use air hose to blow the valve stem clean
3. Practice threading on the pressure monitor so you know you will not cross thread it when doing the final install.
4. Remove the monitor and wrap the valve stem threaded end with 1 to 1-1/2 wraps of plumbers teflon tap
5. Install the pressure monitor, use slight pressure and hand tighten.
6. Drive 30 to 50 miles, and check to make sure they are are still hand tight.
suncoasteng is offline   Reply With Quote
Old 04-04-2019, 04:31 PM   #10
otorvund's Avatar
2018 22' Sport
ok - thank you all!
Old 04-04-2019, 06:47 PM   #11
2016 26' Flying Cloud
Wherever , Texas
Aluminum valve stems a quite common on European cars. I have them on the AS.
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
Bgibbs is offline   Reply With Quote
TPMS - Don't like looks the rear inner value stem! Tao Sprinter and B-van Forum 31 12-15-2015 05:15 PM
Why TPMS is worth it - in my case a DILL TPMS DaKarch Tires 2 08-04-2015 08:37 PM
Followup to valve stem failure dtbw Wheels, Hubs & Bearings 0 10-29-2003 08:40 AM
Valve stem failure on '02 Bambi dtbw Wheels, Hubs & Bearings 12 10-25-2003 10:17 AM
Valve stem Craig Wheels, Hubs & Bearings 1 08-04-2003 05:34 PM
