Old 06-23-2021, 08:45 PM   #1
1988 29' Excella
Lorena , Texas
TPMS - Any low cost and good?
After a ruptured tire on on the way home from our last trip, I'm looking for a TPMS. Prices are all over the map. I know "you get what you pay for", but I also know that the technology is always improving. so my question...
I'm looking for anyone with a TPMS that they've purchased in the last two years, have over 500 miles on, and would rate a 4 or 5 (on a scale of 0-5). Which one did you buy and about how much did you pay for it?
lemley is offline   Reply With Quote
Old 06-23-2021, 09:44 PM   #2
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Have the TST-507 and like it
I installed a TST-507 system with cap sensors last year and put on about 5000 trouble-free miles. I had Discount Tire replace the rubber valve stems with Dill solid metal ones.
I like the color display that cycles through each tire displaying the tire’s temp and pressure. They react quickly to a drop in pressure when I remove them to adjust the pressure.
I bought it for the exact reason you’re looking at it - I want avoid an incident. I got it from eTrailer for $327. I’d give it a 5 out of 5 rating.
Good luck with your decision.
ID:	398073   Click image for larger version
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 06-23-2021, 10:39 PM   #3
Vantair
Vantair's Avatar
2005 25' International CCD
Westlake Village , California
Tst 507
Exactly.
We originally were sold on a few50-60.00 Amazon versions and granted, better than no TPMS at all for a few years.
However….
After some time and the random false alarms every 15-30 mins caused more stress and headaches than the extra cost of a proven and stable (no false) TPMS. In our case a TST 507 with 4 cap sensors. It came with a repeater but with our 25 ft International haven’t needed it yet. With PRE installed metal valve stems on new rims and Michelin’s feeling solid and road ready and MUCH less road stress towing.
Since, no falses and accurate pressures and temps all around.
Vantair is offline   Reply With Quote
Old 06-24-2021, 02:41 AM   #4
2015 25' Flying Cloud
Schaumburg , Illinois
TireMinder
I have the TireMinder TPMS that is made for trailers, but I didn’t buy it, it came with our 25’ trailer (we bought used). It has a repeater, and I have had to move the repeater around to a few different placements to eliminate the occasional loss of data from a sensor. Now that I have found a better placement for the repeater (inside top of the LP tank cover) I consistently see good data continuously from all 4 sensors. I like the system, I power the display via a small USB cable. I get both pressure and temp, You can pick what pressure value to trigger an audible warning.
1StreamDream is offline   Reply With Quote
Old 06-24-2021, 03:03 AM   #5
Sag Harbor , New York
Exclamation TPMS - Any low cost and good?
The best tool for any job is the one that works better than any others.
Saving a few dollars on less-than-perfect tools is a false economy.
How much will you spend traveling and camping in your Airstream over the next 5-10 years?
Maybe $500,000 plus . . . for a total package including tow vehicle, trailer, insurance, gas and oil, maintenance, CG fees, etc.? What percentage of the grand total will a cheaper tool save you?
Don't be cheap!
Life is short . . . enjoy it while you are still healthy and can live the good life!
Happy trails,
Peter
IMO
FYI
FWIW
Let the music lift you up . . .
[Robert Frost reading live -- 2 minutes]
Old 06-24-2021, 05:14 AM   #6
2021 25' International
Winder , Georgia
eez tire - $285 from Amazon
monitor and 4 sensors which is all you need.
no issues yet
Bcc75 is offline   Reply With Quote
Old 06-24-2021, 05:20 AM   #7
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
We've got the TireMinder unit with the dedicated (color) display and are quite happy with it. We had a system from them on our coach, and this one now monitors the TV and Airstream.
The best tire monitor system is the one that you will use every time you head out, so get one you understand and will use. As long as you pick from one of the top tier units you should be okay.
Richard
1974 GMC 4108a - Custom Coach Land Cruiser
richard5933 is online now   Reply With Quote
Old 06-24-2021, 05:31 AM   #8
2019 25' International
Providence , Senior Electrical Engineer
This is what we use and it works great.
https://tirepressuremonitor.com/prod...pulse-sensors/
kittmaster is offline   Reply With Quote
Old 06-24-2021, 05:37 AM   #9
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
My choice Dill internal. Monitors PSI and internal temp. Under $300 at Discount Tire. I've used one for several years, maybe 8 or so. Sensors do have internal battery but the sensors can be replaced w/o buying a complete new system.
https://www.discounttire.com/buy-acc...it-kit/p/87069
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook. BMV-712
GCinSC2 is offline   Reply With Quote
Old 06-24-2021, 05:40 AM   #10
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Switched from Tire Pressure Pro to TST-507 a couple of years ago. Extremely happy with the product. Purchased at a Wally Rally.
Richard
Old 06-24-2021, 06:15 AM   #11
Silvr_Bullet's Avatar
2017 16' Sport
Great Town , US
TireMinder, display is on my iPhone, in settings can choose continuous display of information ( or not ). No effect on iPhone functions, phone, navigation etc. TireMinder has a yearly program $5.00 you get replacement batteries for your purchased system and o-rings. No problems purchased system since 2017. My experience, I highly recommend. Price may be a little higher than most.
Silvr_Bullet is offline   Reply With Quote
Old 06-24-2021, 08:23 AM   #12
RivetED's Avatar
2019 25' Flying Cloud
Airstream - Other
Airstream - Other
North Central Texas , USA
A pleased TST-507 user for 4 years. Works, saved us twice so far, and the display is a good size for what it is, not too big, not too small. Only thing I wish was better is the step-through scrolling display, one tire at a time. No matter which, get a TPMS, best you can afford.
RivetED is offline   Reply With Quote
Old 06-24-2021, 09:16 AM   #13
S/O#080
Tschupp's Avatar
2006 30' Classic S/O
Naples , Florida
Eeze tire. Bought 3 years ago off of Amazon about 250$. After setting up, replacing valve stems to metal, this unit has been great. We did need to purchase a booster as we are 53 feet front to back. Has alerted us to a nail in tire and what turned out to be a valve stem issue on our spare. Unequivocal recommendation.
Tschupp is offline   Reply With Quote
Old 06-24-2021, 09:18 AM   #14
2021 27' Flying Cloud
Winter Park , Florida
Low tech option but I started with just valve stem caps. No ongoing monitoring while driving is a drawback but it let's me do a quick visual check before heading out.
https://www.amazon.com/dp/B01HRIKTYY...ing=UTF8&psc=1
ArstrmComTru is online now   Reply With Quote
Old 06-24-2021, 09:31 AM   #15
2017 27' Flying Cloud
Fernandina Beach , FL
Eeztire
no issues yet
Another vote for Eeztire- works great for us. Have had since 2017. Replaced one failed sensor this year. Trouble free other than that. 27FCFBT with Ram 2500.
Bob Peahl is offline   Reply With Quote
Old 06-24-2021, 09:34 AM   #16
Hampshire , Illinois
I recommend TireMinder Trailer Tire Pressure Monitoring System (TPMS), 4 Tire Kit. The display Velcro’s to your windshield and is solar charged while sitting there (it also has a micro usb cord for charging). I found there customer service very good.
Tom Moquin, 25’ International
debfm is offline   Reply With Quote
Old 06-24-2021, 09:38 AM   #17
Odessa , Florida
no issues yet
This is what I bought after doing my research. I spent closer to 400 but I got 8 sensors. I needed 6 for my Airstream Interstate with dually and thought having a few extra sensors wouldn't hurt. We've put about 20,000 miles on it with no problems.
goldenboy200 is offline   Reply With Quote
Old 06-24-2021, 09:55 AM   #18
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
You spoke correctly - "You Get What You Pay For!"
We have the TST with flow thru senders and these have save our butts - see our blog post
tpms-began-to-alarm/
I implore you - this is one area you do not want to be penny wise and $1000 poor because of a tire failure.
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 06-24-2021, 10:30 AM   #19
Stay CazuaL
cazual6's Avatar
2018 25' Flying Cloud
2014 19' Flying Cloud
Reseda , California
I wouldn't go cheap on safety equipment.
cazual6 is offline   Reply With Quote
Old 06-24-2021, 12:31 PM   #20
grovepark's Avatar
2017 19' International
Melbourne , Florida
Pulse FX package + 2 Pulse Sensors
They work for me
grovepark is offline   Reply With Quote
Good Sam Roadside Assisstance-Good or not so good? flyingfishy On The Road... 27 05-16-2017 01:37 PM
Why TPMS is worth it - in my case a DILL TPMS DaKarch Tires 2 08-04-2015 08:37 PM
Good and Inexpensive TPMS Kit Akronguy Tires 3 05-07-2015 08:58 PM
